Hi another new member
#1 Hi another new member
I have just joined the forum
I am from Norfolk and own a 1962 E-Type Chassis # 379 roadster. The car was purchased as an abandoned restoration attempt in 1999 and over the next three years rebuilt into a lightweight copy. It has the steel tub with alloy bonnet, boot, doors and hardtop. the engine is dry sumped with triple webbers. It is mainly a track day tool when time allows. I also own a 63 3.8 MKII rebuilt as a coombs copy and I am currently building copy of a 53 spec C-Type Jaguar complete with all alloy body.
Kind Regards John
Hi John,
Welcome aboard, plenty of nice guys here and good humour !
Please, post some pictures of your cars especially the LWE !!
And as you problably know already : 3.8 RULES !!
Thierry
Thierry
3.8 RULES
I want to die peacefully in my sleep, like my grandfather,not screaming and terrified like his passengers.
Welcome to the Forum. Interesting selection of cars you have there and pictures would be most welcome. I prepared an easy DIY guide to posting pictures here: http://etypeuk.com/forum/viewtopic.php?t=850 . Give it a try if you have time.
I have been toying with the idea of a C-Type replica and was looking at the Classic Chassis Services (www.ctype.biz) ones.
S1 OTS OSB; S1 FHC ODB
At present I am sitting in my office aboard a VLCC crude oil tanker in the South China Sea, and will not be back in Britain until 23rd Sept. I am not ver computer literate when at home if the choice comes down to sitting at the key board or going into the garage the garage always wins. I was going to say I will post pictures of my car but don't know how yet then I saw the Photobucket Blog so if my car appears you will know I figured it out. Give me a 3.8 XK engine to play with anyday. As you may have guessed I am an engineer
Kind Regards John
Hi Dave,
I am using one of Andy's C-Type Chassis's (C-Type Biz) on my car. He builds an excellent product and is a perfectionist. The alloy body by Aubry Finburgh who owns an original C- Type reg PUR 120 and does mostly alloy work. I build my own engines suspensions and assemble the cars myself. I have already machined up a 3.8 block just ready for assembly, I know it should be a 3.4 but I do like a 3.8 with a big valve head, a pair of Dave Butcher cams and triple webbers. The head is ported the crank tuftrided. JE Pistons on wide blade rods will be used on this engine. It will be similar spec to my E-Type although I used Vernolia pistons in the E-Type engine CR 9.5:1. It made 300BHP on Pete Baldwins Rolling Road. The clearance on vernolia pistons cold is 0.007" which makes them noisy when the engines cold but great when hot. JE use a different alloy spec and don't expand so much and therefore don't require the large clearance so I am giving these a go this time. Crown design on both pistons is very similar.
Kind Regards John
I tried to join Photobucket but access was denied. My company has it blocked for some reason, I will have to join when I get back to Norfolk and post the pictures then.
Kind Regards John
Kind Regards John
:hiya: John welcome to the forum....
I was gonna say its full of knowledge but you seem to know your onions :smackself:
Look forward to seeing the pics
Hi All
Having tried unsuccessfully to get around my companys effects to block various sites I tried to get my car's pictures on the Forum, I remembered I posted my car's picture on the E-Type Data Base site its Chassis 850379. The picture was taken at a track day at Goodwood in 2006 a CKL meeting. I will post more when I get back into civilization.
Kind Regards John
Hi Clive,
Thanks for putting the Thread as you call it to the E-Type data base site I haven't a clue how to do it myself. I really will have to get into this computer jargon. Give me an engine to build any day
Kind Regards John
Hi Guys,
I did try to get some photos on the Forum while in the South China Sea but was unable to access Photobucket due to my company blocking the site. Below are some pictures taken this week of my E-type. I just hope I have done this correctly and they can be viewed.
Kind Regards John
Nice photos John. I see you have the same exhaust system as me (Tony Law?) albeit mine is on a road car. Sounds superb but it is LOUD!
Yes probably "Loud" as well and I bet it's quick too. I wonder if it needs Koolmat, just picked my kit up today and will be installing over the winter.
Lovely looking machine
John H
John H
Hi David,
You are correct it is very loud 105 decibels at goodwood sound check at 4000 rpm. I have just purchased a couple of end cans from a company who say they should reduce the level to 98 decibels. We shall see but they look awful on the car protruding out of the back by at least 8 inches maybe more.
I cannot believe my time at home has come to an end and I travel back to Jakarta on Monday, just time for a day at Stoneleigh on Sunday
Kind Regards John
John,
there's a few of us meeting at the bar at 1pm may be see you there?
Check the meet & greet section for details
