Over excited soon to be owner
Woly64
#1 Over excited soon to be owner
Post by Woly64 » Thu Jan 04, 2018 11:07 am
Have joined as a newbie as the realisation of a long held ambition will hopefully take place on Sat Jan 6th when I pick up a '71 Series 3 2+2 (assuming that my '76 spider that I'm trading in does not let me down in getting there!)
This is how she currently looks...
Jan 2018 small.jpg (152 KiB) Viewed 1448 times
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
#2 Re: Over excited soon to be owner
Post by malcolm » Thu Jan 04, 2018 11:50 am
Well done! Hope all goes well on the day. I've got a webasto roof on my 2+2 and I love it. The open air feel without the battering. My wife (she of the "watch the hair!!") also appreciates it when the wind deflector is up.
Woly64
#3 Re: Over excited soon to be owner
Post by Woly64 » Thu Jan 04, 2018 12:01 pm
Thanks Malcolm - funny that is exactly why I am not buying an OTS and why I really wanted one with a Webasto!
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
Dave K
#4 Re: Over excited soon to be owner
Post by Dave K » Thu Jan 04, 2018 2:21 pm
You should have gone for the OTS and bought one of my windbreakers, no buffeting with that fitted :bigrin:
#5 Re: Over excited soon to be owner
Post by malcolm » Thu Jan 04, 2018 2:32 pm
Ah, but we get dryer quicker when it rains!
Mark Gordon
#6 Re: Over excited soon to be owner
Post by Mark Gordon » Thu Jan 04, 2018 2:34 pm
Yup! 70 mph with Dave's windbreaker feels like about 35 mph. He should pay me for these testimonials. :wink: Dave, have you started making them for Series 3's?
67 OTS 1E14988, 2002 VDP
cactusman
#7 Re: Over excited soon to be owner
Post by cactusman » Thu Jan 04, 2018 7:14 pm
Over excited now....just wait till Saturday :bigrin: :bigrin: :bigrin: :bigrin: :bigrin: bet the first stop will be the fuel station....lol....enjoy :bouncyyellow:
Dave K
#8 Re: Over excited soon to be owner
Post by Dave K » Fri Jan 05, 2018 6:50 pm
Hi Mark, Not yet but I have plans, just need to get hold of a S3 OTS so I can try a few things out.
cactusman
#9 Re: Over excited soon to be owner
Post by cactusman » Sun Jan 07, 2018 7:21 pm
Well Woly64...are you back in from the garage yet....or are you sleeping in the car :bigrin: :bigrin:
Woly64
#10 Re: Over excited soon to be owner
Post by Woly64 » Wed Jan 10, 2018 9:42 am
Bit of both! Apologies for not keeping you posted. Car runs great although the little bugger will not start when hot despite perfect starting at other times. Having read on here the various causes of this I am going to run the fuel right down (guy who sold it mistakenly filled it with ordinary unleaded) then fill it up with high Octane and get the carb set up checked to ensure no weak mixture issue......if all that fails then I will be back on here reading up on ignition issues. It already has a new fuel pump which ticks away nicely so I think that sorting the fuel and mixture set up is the right place to start.
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
#11 Re: Over excited soon to be owner
Post by mgcjag » Wed Jan 10, 2018 9:52 am
Hi Whats your name....please try to put in in the signature area with your car models......you may want to read up on ignition module(opus)....well known to overheat on S3....so causing hot start problems.. Steve
Woly64
#12 Re: Over excited soon to be owner
Post by Woly64 » Wed Jan 10, 2018 9:58 am
Signature sorted - thanks for the prompt Steve. Homework set to understand Opus!
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
#13 Re: Over excited soon to be owner
Post by malcolm » Wed Jan 10, 2018 10:34 am
Although they like high octane if possible, using normal stuff shouldn't cause the issue you mention. I've done a number of European tours (accompanied by S 3's) where it is often really hard to find higher octane fuel. Never causes issues. But good luck finding the issue, and your car looks great!
driver
#14 Re: Over excited soon to be owner
Post by driver » Wed Jan 10, 2018 6:39 pm
Hi,Rob Gill here,
this not unusual on a s3, i had it on mine.
I cured it by fitting a new SNG Barrett ignition/disributor kit,it came with very clear fitting instructions.
All the best.
v12 etype 2+2
Mark Gordon
#15 Re: Over excited soon to be owner
Post by Mark Gordon » Thu Jan 11, 2018 4:38 pm
I had the same problem when I first got my car. It would start instantly when cold, but once warmed up it was a bear. I had the distributor rebuilt and the problem vanished.
#16 Re: Over excited soon to be owner
Post by christopher storey » Thu Jan 11, 2018 6:46 pm
If it starts well when cold, but is a bad hot starter ( my S1 4.2 is as well, and my S2 is not much better ) then if it is a mixture discrepancy, it is more likely to be overrich than weak . It often helps to hold the throttle well open ( say 3/4) while cranking, if it is a hot start difficulty
There are also too many rotor arms around at the moment which become partly conductive when hot, leading to weak spark. The Distributor Doctor's red arms are the cure
Dave123m
#17 Re: Over excited soon to be owner
Post by Dave123m » Thu Jan 11, 2018 7:45 pm
Hi Martin,
Congratulations on the recent acquisition, it looks exactly like mine should, shiny red with a Webasto!
Another vote from me for the Opus Ignition Module being the reason for poor hot starting, I'd definitely be looking there if I were you.
Sadly the biggest issue for you will be both the original Opus & replacement ReOpus are no longer available so it may be an XJS or SNG replacement required.
Mine on the way to Gibraltar below, when I stop using it hopefully I'll get round to restoring it.
Good luck getting it sorted.
Dave.
Barn Find Series 3, 2+2; 38052 Miles when found
Unused 25 Years; found 13.01.12; returned to road 16.05.12
Pace Petroleum Company Car of Aston Martin Chairman Victor Gauntlett
Unrestored, driven to Le Mans Classic (x3), Switzerland, Italy, Gibraltar
Woly64
#18 Re: Over excited soon to be owner
Post by Woly64 » Mon Jan 15, 2018 2:47 pm
Like two peas from a pod! Glad to see you are getting lots of use out of yours - it looks like a fantastic barn find. Enjoy!
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
Woly64
#19 Re: Over excited soon to be owner
Post by Woly64 » Mon Jan 22, 2018 12:02 pm
Well after running the lower octane petrol down and filling up with 98 grade this has made a big difference with much easier starting now when engine hot (happy bunny). Plus from a more detailed investigation the ignition/distributor upgrade has already been done! :bouncyyellow:
Confidence in hot starting = more use now going forward
Martin
1971 Series 3 2+2
MTM RS6 Avant
A1 1.4
Polo 1.2S
