Hello,
This is the first post from a new member.
I'm at the stage of just about having stripped everything off my 3.8 FHC in what is likely to be the most thorough of recommissioning tasks.
Tips and advice on reassembly methods will be gratefully received in the coming months.
Rgds
S
New member in East Anglia
Topic author - Posts: 4
#2 Re: New member in East Anglia
Hi Welcom to the forum...Im sure you will find it very usefull and helpefull. ....please try to put your name and car model in the signature area.....Steve
#3 Re: New member in East Anglia
Hi and welcome! You'll get all the help you need on here
#4 Re: New member in East Anglia
Hi and welcome,
I have completed a nut n bolt rebuild of a 63 fhc last year and there are many others (both ‘amateur’ and professional) who have done the same. So, plenty of help and photos available on this splendid site!
Now running-in my diy nut ‘n’ bolt restoration.
#5 Re: New member in East Anglia
Thanks Richard,
I'm not far down the coast from you in Lowestoft and my car is a few hundred after yours into the final run of the 3.8's.
Steven
Steven
#6 Re: New member in East Anglia
It would be great to see some pics of what you have - once you start the work, post them in the ‘Restoration Stories...’ section so we can follow your progress!
If you do a search in that section, you will see all the other 3.8 restorations which will both inspire, motivate and scare you in equal measure!
Are you planning to do the work yourself? Done this before?
