Garage / workshop
Tasteful jokes.
kingzetts
#21 Re: Garage / workshop
Post by kingzetts » Wed Mar 13, 2019 9:16 am
I've never come across those - neat idea and solves one of my cautionary notes. Just need a drip pan....
John '62 S1 OTS
Barry
#22 Re: Garage / workshop
Post by Barry » Fri Mar 15, 2019 8:24 am
Thanks guys. Excellent advise. A drip pan is the next problem to solve!!!
Gerry
#23 Re: Garage / workshop
Post by Gerry » Wed Apr 17, 2019 7:21 pm
Just a cautionary note,the lift shown is a Mowhawk which is designed with that application in mind,have seen them advertised as a two post storage lift.
Regards Gerry 62 Ots.
GSR 54D
#24 Re: Garage / workshop
Post by GSR 54D » Sun May 05, 2019 7:32 pm
Hi Richard
Another thought is to lower the floor of your garage, as you were thinking of digging a pit anyway.
I lowered my floor at the front by only 15cm which allows me to drive in level onto the ramps of a 4 poster. You could lower the floor further but would have to use a 4 post ramp lift to allow the car to drive onto, 2/3rds of my ceiling is nearly 3 metres high though. The front shown here is about 2.5 metres. This garage is also 3 metres wide and is on the small side for doing work on any car/Etype but is still possible when short of building space. This allows you to store 2 etypes when the time comes!
John H
1962 OTS LHD
1965 FHC RHD
madjack4
#25 Re: Garage / workshop
Post by madjack4 » Tue May 07, 2019 7:16 pm
Hi you can get a 2 post lift over a shallow pit that allows u a low roof but the lift needs no base a bit more expensive but works well
Regards Rob
Barry
#26 Re: Garage / workshop
Post by Barry » Wed May 08, 2019 6:40 am
Hi Rob,
Who makes that and what is the model number?
Barry
#27 Re: Garage / workshop
Post by mgcjag » Wed May 08, 2019 7:33 am
Hi Barry....CJ do a "movable" low height 2 post....2m high post...you (wheel) move into position bolt down then can remove bolts and move away....I have looked at them...very good piece of kit.....http://www.cjautosheywood.co.uk/2post.shtml not sure about fitting one on the edge of a pit unless the floor support was adaquate...Steve
#28 Re: Garage / workshop
Post by Gfhug » Wed May 08, 2019 7:42 am
I wouldn't mind finding a two post lift where both post are on the same side, one for the front, one for the rear of the car with arms to reach out far enough. That way I wouldn't have a post in the middle of my double garage and the two posts could be bolted at the side wall and not take up space in the middle.
Anyone know of this arrangement?
#29 Re: Garage / workshop
Post by mgcjag » Wed May 08, 2019 7:50 am
Hi Geoff...plenty of single post lifts about..not exactly as you describe...just google search single post lift
Automotech have very good products...iv seen some of their lifts but not this one https://www.automotechservices.co.uk/pr ... icle-lift/
You may not be able to drop your engine/gearbox with this
#30 Re: Garage / workshop
Post by Gfhug » Wed May 08, 2019 9:17 am
Thanks Steve, they might help. I was also thinking of it being used to store one car above another, hence the thought of two posts. Could do with the extensions you posted above to support by the wheels so no load is left on the IRS for long periods.
But that is a good suggestion, must collar one or two companies at the restoration shows.
Barry
#31 Re: Garage / workshop
Post by Barry » Wed May 08, 2019 6:00 pm
Thanks Steve for the links. Really interesting and will make up my mind.
Barry
rfs1957
#32 Re: Garage / workshop
Post by rfs1957 » Thu May 09, 2019 11:25 am
Anyone considering garage design might like to delve back into the Forum
http://forum.etypeuk.com/viewtopic.php? ... oundations
where two-post lifts were sneered at, but FWIIW I can confirm that - having worked with both two and four in the past - this type of Italian lift, that I have now been using for over 10 years, has been perfect in every sense for working on the E-Type.
https://www.wertherint.com/wp-content/u ... 170203.pdf
There's a good dimensioned drawing in this that enables one to work out how it might fit.
The idea that they're imbalanced, that cars tip-up with the engine out, or with the diff out, is simply nonsense - I have had every imaginable configuraion of this-in and that-out, and it remains the best money I've ever spent.
In the most unfavourable and potentially imbalanced configurations I've even tried to provoke problems, by hanging off the front or the back, just to test the theories of the nay-sayers.
Certainly, lifting anything above ground-level has the potential to convert its potential energy into an injury, but as I said at the time -
"If I didn't think I was safe enough to work all this out for myself, I wouldn't be working on my own brakes, steering, chassis, suspension etc and would just confide all my car maintenance to a specialist garage."
The ONLY aspect I could fault is that I can't quite get the doors 100% open, so re-fitting them requires a little more care, but that's the only niggle I can think of.
There are other similar ones on the market, but the Werther is available in the UK, here amongst others
https://www.straightset.co.uk/werther-3 ... tonne.html
and here
http://www.pmdgarageequipment.co.uk/bon ... t.lift.3t/
and if anyone wants any other measurements or pictures or advice just PM me, or get a £50 return EasyJet/Ryanair flight and come and have a look.
1978 Mini Van
