What’s missing from yours?
Observations on servicing costs, mpg, wear & tear, breakdowns and experiences on the road
#1
Postby chrisfell » Tue Oct 10, 2017 9:39 pm
Some while ago, probably on another forum, I was astonished to discover that the air plenum chamber should have had a seal around the carb plate. And another seal should have existed around the top of the radiator. No such seals existed on my car. Since then I’ve discovered exhaust heat shields, various pieces of internal trim, many screws and bolts, a number of clips and several pieces of foam and rubber around the gearbox tunnel are no longer on my car, if indeed they were ever fitted.
I also know that my car wears S2 front uprights and brakes, as well as the thicker torsion bar. But what’s missing from yours or changed and do you know why?
ralphr1780
Re: What’s missing from yours?
Postby ralphr1780 » Wed Oct 11, 2017 8:49 am
Good query Chris.
Yet missing, at least that I know of, and funnily on both my S1 and S2:
radiator foam-to-bonnet
2 small rubber mud protection in the bonnet
rubber flaps along torsion bars
clip on bellhousing for speedo cable
accelerator pedal return spring
Must be some more...so keen on reading other's.
Ralph
'69 OTS + '62 OTS - Belgium
golfnut324
Postby golfnut324 » Wed Oct 11, 2017 11:09 am
A Jag-lovers thread from a couple of months ago pointed out this missing bracket, which secures the bonnet plug near the bonnet hinge:
http://www.sngbarratt.com/ProductDetail ... bdc527&l=7
Now on order and to be installed soon.
Craig
'68 E-Type FHC
cactusman
Postby cactusman » Wed Oct 11, 2017 4:35 pm
If I wrote a list of all the fiddly bits that were missing when I got mine it would fill a book. Some were obvious at the time....others not....many bits have been sourced but I still have a good few to go!! Anyone got a gear box vent pipe for example....I know it should be in the wanted section btw....I ain't too optimistic....
tim wood
Postby tim wood » Fri Oct 13, 2017 7:11 am
Gearbox vent pipe on ebay now, item. Number
253205558367
Not cheap !
Tim
Series 1 2+2 now sold
Seeking an OTS, hopefully to be repatriated from the US shortly.
Postby chrisfell » Fri Oct 13, 2017 7:54 am
“If I wrote a list of all the fiddly bits that were missing when I got mine it would fill a book”
Er...., I did.
cactusman
Postby cactusman » Fri Oct 13, 2017 7:36 pm
Good spot Tim...thanks....will watch....who knows....I might get a bid in...
can't top your reply Chris....brilliant
Postby abowie » Fri Oct 13, 2017 10:56 pm
Currently?
my 3.8 FHC has no floors, kick panels, sills, boot floor, rear wheel arches.....
Ross the panel man sent me a load of pics of the progress.
It was like looking at the pics in the Karma Sutra. You have to turn them around a couple of times before you work out what you're looking at..
881824, 1E21538. 889457..oops
#9
Postby abowie » Fri Oct 13, 2017 10:59 pm
Oh and I forgot door skins and there may be one panel on the bonnet we'll be able to reuse..
#10
Postby abowie » Fri Oct 13, 2017 11:05 pm
This is from the invoice for most of the replacement panels...
Outside Courier @ 294.41 Kgs
ORDER LINE PART NUMBER DESCRIPTION QTY PICKED PACKED
REQ
38976 11 BD15133/1 SILL OUTER RH 1 1 1
38976 10 BD15134/1 SILL OUTER LH 1 1 1
38976 46 BD15137 TRANS TUNNEL SIDE RH 1 1 1
38976 7 BD15165 BATTERY CARRIER 1 1 1
38976 24 BD15180 B/HEAD SIDE PANEL RH 1 1 1
38976 25 BD15181 B/HEAD SIDE PANEL LH 1 1 1
38976 3 BD15184* RHF SILL END PANEL 1 1 1
38976 4 BD15185* LHF SILL END PANEL 1 1 1
38976 6 BD15186* BATTERY TRAY MTG BKT 1 1 1
38976 5 BD15187* AIR CLEANER MTG BKT 1 1 1
38976 44 BD16381 MUDGUARD BONNET RHR 1 1 1
38976 41 BD16422 BONNET DIAPHRAGM RH 1 1 1
38976 42 BD16423 BONNET DIAPHRAGM LH 1 1 1
38976 14 BD16488 SILL STIFFENER FT 2 2 2
38976 1 BD16943 BULKHEAD PANEL LH 1 1 1
38976 34 BD18945 LIGHT FILLET RR RH 1 1 1
38976 33 BD18946 LIGHT FILLET RR LH 1 1 1
38976 37 BD19029/1 BONNET BEADING LONG 4 4 4
38976 39 BD19029/2 BONNET BEADING SHORT 4 4 4
38976 38 BD19030 BONNET BEADING CLIP 22 22 22
38976 21 BD19340/4 TONNEAU PANEL RR 1 1 1
38976 30 BD19741 DOOR SKIN RH 1 1 1
38976 31 BD19742 DOOR SKIN LH 1 1 1
38976 27 BD19930 SIDE PANEL 1 1 1
38976 26 BD19931 SIDE PANEL 1 1 1
38976 12 BD27754 SILL STIFFENER RH RR 1 1 1
38976 13 BD27755 SILL STIFFENER LH RR 1 1 1
38976 22 BD28106 LIGHT HOLDER RH 1 1 1
38976 23 BD28107 LIGHT HOLDER LH 1 1 1
38976 2 BD28248 BULKHEAD PANEL RH 1 1 1
38976 15 MRE014RH RH FULL FLOOR ASSY 1 1 1
38976 8 MRE015LH INNER SILL LH 1 1 1
38976 9 MRE015RH INNER SILL RH 1 1 1
38976 20 MRE021LH LHR SILL END PANEL 1 1 1
38976 19 MRE021RH RHR SILL END PANEL 1 1 1
38976 17 MRE024LH LH X MEMBER TO FLOOR 1 1 1
38976 18 MRE024RH RH X MEMBER TO FLOOR 1 1 1
38976 29 MRE026LH RR W/ARCH REPAIR LH 1 1 1
38976 28 MRE026RH RR W/ARCH REPAIR RH 1 1 1
38976 32 MRE036A BOOT FLOOR 1 1 1
38976 35 MRE039/040A NO PLATE PANEL ASSY 1 1 1
38976 36 MRE042 REAR CLOSING PANEL 1 1 1
38976 45 MRE092 BONNET PICTURE FRAME 1 1 1
38976 40 SBS9047 ALLOY DASH KIT 1 1 1
38976 48 SNG014LH FULL FLOOR ASSY LH 1 1 1
SNG BARRATT UK PACK TICKET ZZ95910 PAGE 3
Payment Method: AUTO PDQ VAT 1 RATED GOODS TOTAL 4,588.25
VAT 2 RATED GOODS TOTAL 0.00
Card Ending: x0333 SHIPPING AMOUNT 1,600.00
VAT AT RATE 1 (0.00%) 0.00
VAT AT RATE 2 (0.00%) 0.00
GRAND TOTAL 6,188.25
#11
Postby Series1 Stu » Sat Oct 14, 2017 8:08 pm
Gulp!
'94 X300 XJR basket case
#12
Postby abowie » Sat Oct 14, 2017 9:10 pm
Series1 Stu wrote:Gulp!
Well the car was described as "unrestorable" on XKDATA.....
#13
Postby Series1 Stu » Sat Oct 14, 2017 9:15 pm
We like a challenge!
#14
Postby abowie » Sun Oct 15, 2017 12:10 am
I only bought it because it was otherwise pretty much complete and it was already in Australia.
I have pretty much finished refurbishing all of the other components and the body shell will be ready around April next year.
Turnip
#15
Postby Turnip » Sun Oct 15, 2017 9:11 pm
tim wood wrote:Gearbox vent pipe on ebay now, item. Number
253205558367
Not cheap !
Tim
I don't know if the vent pipe for a '62 is the same as a '65, but I got one for mine from SNG for about £35 (C25028).
And then I found the original one in a pile of bits.
1965 Series 1 4.2 FHC
Turnip
#16
Postby Turnip » Sun Oct 15, 2017 9:14 pm
Parts that don't appear in the pictures in the Parts manual seem to be a problem.
On mine I found that the spacers at the bottom of the picture frame and those under the engine mounts were worthwhile upgrades.
And then we can have a worry thread about all the bits we have left over after a rebuild.
Return to “E-Type Running Reports”
Who is online
Users browsing this forum: No registered users and 1 guest
