Lucas battery…
#1 Lucas battery…
Would anyone know if you can buy one of those quality period look Lucas branded (embossed) 12 volt car battery please in the UK?
I have seen them on American sites but not it in the UK.
Thanks.
David
Thanks.
David
#3 Re: Lucas battery…
Hi Daryl,
Thanks for your response.
Sadly not the right battery, the one I have seen pictures on has LUCAS in raised letters on the casing.
Thanks again.
David
Thanks again.
David
#4 Re: Lucas battery…
Look at these topics:
viewtopic.php?f=3&t=4426&p=135844&hilit ... er#p135844
viewtopic.php?f=9&t=16142&p=132459&hili ... er#p132459
Searched on Lucas, then those results for sticker and found these two of several topics that will help you.
#5 Re: Lucas battery…
There was a company selling repro Lucas cases with a modern battery inside - Antique Car Battery Co or some such. Search for battery in the Upgrades Forum for more info. Very expensive to buy and even more costly to ship over. Not sure they are still in business of classic batteries: https://www.antiqueautobattery.com/
I have a Halfords battery decked out with a faux Lucas plate and stick on red filler plugs. Works well and detailed in the upgrades section: viewtopic.php?f=3&t=4426
This is what I did:
A Yuasa YBX3113 (DIN 56011) battery; £54: https://www.thebatteryshop.co.uk/yuasa- ... 8858-p.asp
Stickers removed and this kit applied; £20 from eBay seller Weskcar:
The alternative if you want the +ve post on the other side is a Halfords HB030; £80: https://www.halfords.com/motoring/batte ... 74064.html
Remove stickers and apply this kit; £20 from eBay seller Weskcar:
The black embossed Lucas battery was used up until the end of 3.8 production. The FRV 117A labelled battery with the red caps was used on the 4.2 cars and obviously for replacement of the earlier Lucas style. When searching for a replacement battery take the hold down bracket with you as sizes vary even though they are all supposed to be DIN 56011 spec size - 236 x 178 x 182mm (LWH).
The rubber cased, bitumen sealed batteries from Lincon, Shield and Fuller are a nightmare because they will invariably leak. This is because the Factory hold down bracket causes the battery walls to distort usually next to one of the terminals. It was a problem in period and Jaguar tried various fixes - Thackary washers and three iterations of rubber buffers. Not a problem with these modern plastic batteries and they are half the price!
This is what I did:
S1 OTS OSB; S1 FHC ODB
#6 Re: Lucas battery…
Thanks for your reply.
I have taken a look on eBay but unable to find the Weskcar kit of black Lucas embossed plate and cell caps?
Thanks again.
David
Thanks again.
David
#7 Re: Lucas battery…
Get one 3D printed.....Steve
#8 Re: Lucas battery…
https://www.ebay.co.uk/str/weskcar
Doesn’t seem to have Lucas presently.
1965 S1 4.2 FHC (early)
#9 Re: Lucas battery…
Did you find anyone else that you could get the Lucas battery tops from
