New Forum Features
#21 Re: New Forum Features
Hi David
I can see images 1 and 4 but not 2 and 3 on my Samsung tablet.
You may recall that we corresponded sometime ago about this issue.
Many thanks for your efforts to resolve the problem.
Ian
Ian
Ian Cooke
1969 S2 FHC in Old English White
Topic author - Administrator
#22 Re: New Forum Features
Can anyone see the third image? The one after the girl photos and before the engine support. It has a small icon with the word 'image's after it. I.e. this one:
S1 OTS OSB; S1 FHC ODB
#23 Re: New Forum Features
David, a bit of feedback, all I can see on my Mac is two of the lady and one of Rory's engine stand, no third one or the word image.
#24 Re: New Forum Features
I cannae see it running Chrome on my PC - a combination which usually opens most things
1969 S2 FHC - 1R20258
#25 Re: New Forum Features
My suggestion is to use IMGUR - no idea why Postimage is behaving this way on selected posts and help is non existent on Postimage.
#26 Re: New Forum Features
Thanks for all your efforts and time on this David.
I ask for a bit of further clarification:
Presumably you believe this problem is resulting from the way folks add the pictures into their posts rather than how we are viewing posts. So I presume therefore that clicking on that link (P Add image to post) which is just below the box I am now typing into is the Postimage method.
I have no idea as to what is IMGUR ......... though perhaps I would find out with good ole google
.... or maybe you will enlighten us
Thanks.
Thanks.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#27 Re: New Forum Features
IMGUR is a photo hosting web site similar to Postimage but a lot slicker and allows you to control and organise your ohotos. It has some editing tools as well so you can rotate photos for example. You need to register but other than that it is free and there are no adverts or spam emails.
I can't understand what is happening with those images on Postimage because the later ones display fine. I will keep digging and see if any fix turns up.
#28 Re: New Forum Features
I see exactly what you describe.
I get a problem with Postimage in that sometimes it works and sometimes it doesn't when posting images. It seems to change its mind about what image size it likes.
Software that lacks the Y chromosome, perhaps?
'78 Land Rover Series 3 109
#29 Re: New Forum Features
Well it seems to be something to do with Postimage alright. I tried a direct link to Rory's photo: https://s10.postimg.org/hn1glna09/Engin ... ingers.jpg and I get this response:
"This site can’t be reached s10.postimg.org took too long to respond."
I then tried changing the url address to point at postimage.cc rather than postimage.org and it works!
https://s10.postimg.cc/hn1glna09/Engine ... ingers.jpg
Try clicking on both links and see if you get the same. Looks like they changed their web address or are using an alternative. All new posts via Postimage should work correctly and if your old photos do not display try editing your post and change the address to .cc rather than .org
#30 Re: New Forum Features
Hi David...your first link dosnt load..just sits waiting.....second link loads straight away...Samsung tablet.. Steve
#31 Re: New Forum Features
Ditto - PC and Chrome
#32 Re: New Forum Features
That confirms it Postimage.cc is their new home. The Postimage function still works so continue to use it if you wish. All your previous posted photos will not display unless you change the .org to .cc in the image address.
#33 Re: New Forum Features
Yes, that's it! Changing the .org to .cc fixed one of my photo posts. Now to find all the others...
#34 Re: New Forum Features
Well, David,
this saga seems to continue. In this thread:
viewtopic.php?f=8&t=8874&start=200
in post 211 I see Richard has posted 3 pictures using .cc
I can see the first 2 but the third is just a picture place holder only. If I hover the mouse pointer over each it shows the link to postimages.cc only (on all 3) If I click on one of the images I scan see (I get no blue border BTW) I go to a blank page.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#35 Re: New Forum Features
If you copy the addresses of post 211 that Jerry mentions above with link the first two are cc and the third is org.
https://s10.postimg.org/ct45l9up5/0778_ ... 2_C338.jpg
Another is post 204 in the same thread by Richard has many pictures with the .org which cannot be seen.
https://s9.postimg.org/4i8o1qd33/A11_EE ... _D71_E.jpg
#36 Re: New Forum Features
mmmm. Very odd. If I hover mouse pointer over each picture in Richards post 211 I get postimage.cc for all 3 (I don't know how you copy the addresses)Geoff Green wrote: ↑Mon Apr 30, 2018 11:48 amIf you copy the addresses of post 211 that Jerry mentions above with link the first two are cc and the third is org.
If I right click on your links Geoff, and open in new tab, I get "This page cannot be displayed" ...... because they are postimage.org links
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#37 Re: New Forum Features
David, I continue to have difficulty with this.
How do I upload an image to postimage.cc as opposed to postimage.org?
If I use the "Add image to post" link below this text box, it still seems to go to postimage.org and whilst the uploaded image appears in the post, clicking on it does not find the full size image.
Inserting a link to an image in Dropbox does just that and does not open the picture in the post. Using the "Insert Image" button does not produce the image either.
I'm finding it hard to get the hang of this
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#38 Re: New Forum Features
When you click on the Postimage link first set the image size to 1920 x 1080 from the drop down. Click on upload image and select your photo. Postimage will insert a link that looks something like this:
{url=htps://postimges.org/][img]htps://s8.postig.cc/nm8dupyfp/Ft0n2_HX.jpg[/img][/url]
You will see the first url has the .org address whilst the second has the .cc address. What you now need to do is delete the {url=htps://postimges.org/] prefix and the {/url] suffix. This will leave you with {img]htps://s8.postig.cc/nm8dupyfp/Ft0n2_HX.jpg[/img} Your image will display and clicking on it on a PC will enlarge it:
You know you have got it right as when you hover your mouse over the photo a blue border will appear. On smartphones and tablets the photo will maximise automatically so no need to click or tap on it.
#39 Re: New Forum Features
Did not work quite as you detailed above because for some reason this time it gave me postimages.cc rather than .org. However, when I deleted the bits you advised - success. Thanks very much.
Also, I did not get the option to resize to 1920 x 1080, so I did it myself first. Then avoided the "resize" option for the upload.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#40 Re: New Forum Features
Hi I have saved a draft post, how do I recover it?
Jaguar E type S2 OTS 1969, Daimler V8 250 1968, MGB GT 1978, VW T1 Bay Campervan 1978, Triumph 3T 1946 (1st owner William Lyons) BSA Golden Flash 1954, Velocette Venom 1958, Norton Commando 1972, Honda CB400 4 1977
