Advice on rustproofing treatment please?
#21 Re: Advice on rustproofing treatment please?
Post by malcolm » Wed Oct 24, 2018 4:17 pm
Hi all. To access the sills, for potential Dynax spraying, is there an existing access hole, or do I need to drill one? And would the spray can reach far enough to coat the whole inside of the sill from one access? I can't see an obvious bunged hole!
If I have to drill, where is best to go? I can just about see Steve's chart, but not sure if that is indicating the section to deal with, or where to gain entry.
Jeremy
#22 Re: Advice on rustproofing treatment please?
Post by Jeremy » Wed Oct 24, 2018 8:04 pm
I drilled a hole at the rear end of each sill from the wheel arch (10mm I think) and you can get neat plugs from one of the derusting suppliers (can't recall who I'm afraid). Took out one of the engine frame bolts to attack it from the front end. You can also get in there through the holes inside the car, where the inner sill meets the floor.
Jeremy
1967 S1 4.2 FHC
#23 Re: Advice on rustproofing treatment please?
Post by christopher storey » Thu Oct 25, 2018 7:40 am
And if you take the carpets out and peel up the vinyl sill covers just an inch or so, you will see a series of holes in the inner sill leading directly into the sill cavity
#24 Re: Advice on rustproofing treatment please?
Post by chrisfell » Thu Oct 25, 2018 8:25 am
On my 2+2 there is one per side, looking like this.
#25 Re: Advice on rustproofing treatment please?
Post by malcolm » Thu Oct 25, 2018 8:31 am
That's great info, thanks. i feel up to the job now!
JerryL770
#26 Re: Advice on rustproofing treatment please?
Post by JerryL770 » Fri Oct 26, 2018 4:47 pm
Those injection plans are here:
viewtopic.php?f=2&t=2789
Jerome Lunt
#27 Re: Advice on rustproofing treatment please?
Post by malcolm » Sat Oct 27, 2018 8:39 am
Thanks jerry
