Fuel filter rubber seal failure
Topic author - Posts: 44
#1 Fuel filter rubber seal failure
Hi All,
I carried out an engine oil & filter & fuel filter change in December, in fact on the 16th of December. I then started and ran the engine up to operating temperature checking for leaks. Then switched it off, it has not been run again until tonight. I have been working on the car over the last week fitting a classic fabs long manifold system, taking the opportunity of degreasing/cleaning the engine bay, floor pan and rear suspension while the exhaust was off. It is now gleaming. The reason I spit & polished the underside was because it was covered in a thin coat of black oil film. That’s another story!
I went to start it up tonight, switched the ignition on and waited for fuel to get to the carbs before I turned it over, unusually it didn’t start. I switched off then back on, listening to the pump whirl I could hear heavy dripping. Fuel was being dumped on my garage floor.
The new rubber seal that came with the new fuel filter has been effected by petrol, it has got larger and gone out of shape. I fitted another one from the same supplier that I had but am no confident with it. The failed one has only been in just over 2 months.
Has anyone had a similar problem and can anyone please advise where I can purchase a good quality seal that will not be effected by petrol.
Thank you in advance
Paul. 1962 Series 1 roadster 850543
1965 mk 1 Lotus Cortina
1973 Triumph Stag (had it since 1982)
#2 Re: Fuel filter rubber seal failure
Hi Paul...what model do you have....please try to put it with your name in the signature area......i assume your refering to the glass bowl seal.....Iv not had a problem and havent heard of this but could be a problem waiting to happen if seals have been changed by suppliers.....have you been intouch with the supplier for their answer........post a photo would be good.....Steve
#3 Re: Fuel filter rubber seal failure
#4 Re: Fuel filter rubber seal failure
Hi again all,
I am looking at purchasing a new rubber seal for the glass fuel filter. Can anyone recommend a good supplier. Ideally from one of you who has replaced their filter & seal which has been in place for a long while without issues.
#5 Re: Fuel filter rubber seal failure
SNGB works for me https://www.sngbarratt.com/uk/#!/Englis ... 500fa3f8b9
#6 Re: Fuel filter rubber seal failure
Me too - just a little bit of care to ensure it’s seated accurately.
Series 2 FHC 1970
1R 20607
1R 20607
#8 Re: Fuel filter rubber seal failure
Thanks guys, I have just ordered a couple, I have been using Barratts for various parts over the last week, I must admit I am impressed with their service
#9 Re: Fuel filter rubber seal failure
The fuel filter glass bowl seals along with other parts turned up from Barratts today.
I replaced the seal that I only fitted on Thursday night, it has already grown in size in that short time.
Hopefully the barratt ones will be of better quality!!!!
