Wire Wheel Spanner
SimonBrown
#1 Wire Wheel Spanner
Post by SimonBrown » Tue Mar 19, 2019 10:24 am
Having just had my wire wheel spinners (Federal Type) re chromed, I can't quite bring myself to use the original spanner on the new chrome.
Does anyone know if there is a Federal spanner available that will not mark the spinners?
Thank you
Simon Brown
S2 OTS
#2 Re: Wire Wheel Spanner
Post by mgcjag » Tue Mar 19, 2019 2:33 pm
Hi Simon...yes you can get an aluminium tool...you will need a large socket and breaker bar to use it....lots of info in this thread....Lionel is the chap that makes them..his contact number is in the last post......for the standard federal style tool i put a thick rag over the spinner then fit the tool (its tight).....then use the hammer....Steve
http://forum.etypeuk.com/viewtopic.php? ... inner+tool
AshM
#3 Re: Wire Wheel Spanner
Post by AshM » Wed Mar 20, 2019 2:07 pm
Let us know how you get on Simon. Keen to get a similar tool if they are still available.
I hate the mallet (don’t ask me why!).
Ash
Series 2 FHC 1970
1R 20607
#4 Re: Wire Wheel Spanner
Post by Gfhug » Wed Mar 20, 2019 2:28 pm
Just to add that I've one of the Lionel adapter tools and they do a fine job. Steve's comment about a rag is important.
SimonBrown
#5 Re: Wire Wheel Spanner
Post by SimonBrown » Wed Mar 20, 2019 2:47 pm
Thanks Guys
Lionel is on holiday at the moment, but will contact me on his return next week.
I will let you know how I get on
Simon Brown
S2 OTS
Mich7920
#6 Re: Wire Wheel Spanner
Post by Mich7920 » Thu Mar 21, 2019 1:05 pm
https://www.oldtimertools.de/
The best tools for the best car !
Michel
1963 E Type OTS - Angus Restoration
1965 E Type FHC - On the road at last !
#7 Re: Wire Wheel Spanner
Post by mgcjag » Thu Mar 21, 2019 4:23 pm
Hi Mich...the spinner tool is about 3 times the price of the ones Lionel makes....Steve
Mich7920
#8 Re: Wire Wheel Spanner
Post by Mich7920 » Thu Mar 21, 2019 5:30 pm
I know steve but the top quality isn't cheap.
I'm always nervous when the "same" thing cost 3 times less price.
I sell quality tools among others and I see almost every day the "same" 3 or 10 times less price.
But it seems to work pretty well for its price so...
Michel
JerryL770
#9 Re: Wire Wheel Spanner
Post by JerryL770 » Thu Mar 21, 2019 5:38 pm
The torque which Oldtimertools recommends is 258ft.lb :seeingstars:
Long tommy bar!
Jerome Lunt
Mich7920
#10 Re: Wire Wheel Spanner
Post by Mich7920 » Thu Mar 21, 2019 5:57 pm
I bought the one which cost 169.00€ and it's not a big price for the tool I received.
They are obliged to give a so big torque.
1 - They don't want any responsability if there is an accident.
2 - They say by this hight torque that their tool can resist to this.
Intelligent marketing.
Michel
#11 Re: Wire Wheel Spanner
Post by Series1 Stu » Thu Mar 21, 2019 11:33 pm
Since the Oldtimers tool is only suitable for fitting the spinners, what do you use for removal?
In fact, when they say the forces required to remove are higher than for fitting, this proves that the spinners tend to self tighten, as discussed previously on this forum.
'94 X300 XJR basket case
Mich7920
#12 Re: Wire Wheel Spanner
Post by Mich7920 » Fri Mar 22, 2019 5:51 am
Oldtimer and Lionel 's tools are both of course for fitting and removal the spinners.
Michel
JerryL770
#13 Re: Wire Wheel Spanner
Post by JerryL770 » Fri Mar 22, 2019 6:19 am
I've not read the debate on self tightening of spinners.
However, if you tighten any nut to a torque and leave it for a time, it will invariably require a greater break-out torque to undo it. All to do with lube being squeezed out (possibly) but more significantly, static friction (force needed to get it moving) is always greater than moving friction. (going back to physics classes/lab :roll: )
Jerome Lunt
#14 Re: Wire Wheel Spanner
Post by Series1 Stu » Fri Mar 22, 2019 1:22 pm
That's incorrect Jerry.
Loosening torque is always less than tightening torque due to overcoming friction as the nut etc starts to clamp the joint and then putting stretch into the threaded fastener. Engineering fact.
The reason for undoing often being more difficult than tightening is usually down to corrosion etc.
Mich
The Oldtimers website clearly states that it should only be used for tightening spinners and then used again once the car has been driven a little.
I think I'll stick to my wooden spinner saver.
Mich7920
#15 Re: Wire Wheel Spanner
Post by Mich7920 » Fri Mar 22, 2019 5:47 pm
Funny!
When a key is usually indicated to tighten 1/2" bolts, what do you use to loosen them?
If you are happy with your piece of wood, it's ok for me. No problems at all. :shrug:
Michel
#16 Re: Wire Wheel Spanner
Post by Series1 Stu » Fri Mar 22, 2019 7:19 pm
My point exactly! What is the point of having one tool to tighten and another method of loosening? It's a waste of money and tool box space.
#17 Re: Wire Wheel Spanner
Post by mgcjag » Fri Mar 22, 2019 8:01 pm
Dont know what tool you are looking at on the old timers site....but the op was asking about federal type....the Site says for tightening...and ...lossening https://www.oldtimertools.de/Vehicle-Ty ... JA-33.html
#18 Re: Wire Wheel Spanner
Post by Series1 Stu » Fri Mar 22, 2019 10:40 pm
Yes, sorry. Having re-read the write up, it says don't use the torque wrench for loosening.
Geoff Green
#19 Re: Wire Wheel Spanner
Post by Geoff Green » Sat Mar 23, 2019 6:06 pm
Loosening using a torque wrench will change the setting and not be correct for tightening. 100 foot lbs on the are point will be different and need 95 or 105 foot lbs to move to the 100 foot lbs reading. You will have to calibrate the torque wrench again.
#20 Re: Wire Wheel Spanner
Post by Series1 Stu » Sat Mar 23, 2019 6:26 pm
Sorry Geoff, that makes no sense.
