mtnjag wrote: ↑Sat Dec 12, 2020 6:36 pm
. . . . and can't even get the tire fully off the ground!
Using the crank (looks to be the same one that is shown with the jacks) that came with the jack and it gets so hard to crank it won't actually lift all the weight.
Easy to work with no load, starts to lift body fine, gets progressively harder to crank and then forget about it.
That does not seem to make sense to me. With the jack fully collapsed (down) the lever arm for lifting weight (the car) is at its worst condition and when the jack is mostly raised the lever arm is at its best.
That is (illustrative only) when the jack is down, 1 turn of the crank will be lifting the weight say 1 inch but when the jack is up, 1 turn of the crank will lift the weight maybe 1 tenth of an inch. So as the weight is raised, the effort to turn the crank should decrease. If yours increases, there is something wrong with the jack.
