OBL = $565k
#1 OBL = $565k
A beautiful 1961 E-type Coupe was just hammered sold at the Gooding & Co. Monterey auction for $565,000, (not including buyer’s premium).
The car was supposedly subject to a 4,000+ hour restoration.
Unfortunately, there was black paint in the JAGUAR name on the spinners, which spoiled the whole thing for me.
Alan
N.J.
Alan
N.J.
#2 Re: OBL = $565k
Really, that's an outrage!
'78 Land Rover Series 3 109
#3 Re: OBL = $565k
$565k, bloody hell you can buy a new car for less than that
1972 V12 Roadster. Velar. M5. Caddy. Bikes.
#4 Re: OBL = $565k
Is this the one....estimate was $650-$750 https://www.goodingco.com/vehicle/1961- ... ead-coupe/ Are the spinners repro....our expert will know.....boot trim looks baggy....and whats going on with that wiper blade
#5 Re: OBL = $565k
Yes, repro 'Jacuar' spinners with black paint. Shame as it is a rare car. For that money you think they would have sprung for an original key fob!
S1 OTS OSB; S1 FHC ODB
#6 Re: OBL = $565k
Xkedata has it listed as a $400k restoration and multiple 100 point concours winner
#7 Re: OBL = $565k
Mat isn’t baggy Steve. Is it too high at the front?
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#8 Re: OBL = $565k
It has the wrong bumper seals - they should be thin.
The brake bottle caps should be NIVOCODE
#9 Re: OBL = $565k
With 4,000+ hours of labour, plus parts and the original cost of the car I think this bloke is under water at $565,000!
Alan
N.J.
Alan
N.J.
#10 Re: OBL = $565k
Agree 100% that the buyer is underwater with this one, unless the car has some sort of provenance we haven't heard about. He/she apparently got caught up in a feeding frenzy with no way out, and will be taking a significant haircut down the road.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
#11 Re: OBL = $565k
Another supposed “100-point” 1961 OTS (OBL) was just hammered sold at $340,000 at the RM Sotheby's Monterey auction.
I can’t explain the $225,000 differential between the two cars.
Alan
N.J.
Alan
N.J.
#12 Re: OBL = $565k
The review view mirror on 885018 also is incorrect - should have the pointed (not curved) stem.
The one fitted is from a later car.
#13 Re: OBL = $565k
Overriders look a bit on the wonky side?
Out of interest, we see a number of these cars advertised as 'subject to a blah-blah-blah number of hours' restorations. I'd be interested to know what other people's experiences of professional restorations are, and maybe Angus's too as he obviously has to keep records of the ones he does, but my own car - which was absolutely stripped apart to the last nut and bolt and had a full mechanical rebuild and all the usual metalwork replacements needed - ran out at 1,288 billed hours, and the only things done externally were the retrim, the roadwheel restoration, and the Webasto set-up, so maybe another 200 hours for those three items?
No car is perfect, but having been able to compare mine to others over the last five years I'd say mine certainly stands its ground amongst the better ones, so if we assume mine was, say 1,500 hours all in, I'd be interested to know what the additional 2,500+ hours on a restoration like the one featured here supposedly goes on?
1969 S2 FHC - 1R20258
#14 Re: OBL = $565k
Arguably sourcing original parts? Also I see the bonnet was missing so making a new one with the original shape louvres would have taken a lot of time to complete.
#15 Re: OBL = $565k
When you click on the documentation link you can load up the JDHT certificate. This has the word "originally" in front of each of the main numbers. This seems a bit strange in the circumstances of what is claimed to be a fully numbers matching car. Looking at the engine number on the head, it does not appear to have a "1" on its side between the last engine no. digit and the "9" for the compression ratio. Was this like it on all the heads or did some have a simple "dash"?
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#16 Re: OBL = $565k
As in spinners, bumper seals, bottle caps, mirror stems and key fob?
Point taken on the bonnet though.
I think in general my point is that whilst the costs of a full-blown professional restoration will vary greatly - driven by the hourly labour rate - the actual number of hours expended should be fairly constant. The talented home restorer will of course take longer (a) because they can, and (b) because to a certain extent they're learning on the job, but the experience built up by the professional restorer should mean that they can go straight to the heart of the problem each time and remedy it far more quickly and efficiently: likewise using their established network of contacts to source harder to find parts. Put another way, all other things being equal any home restorer would be likely to finish their second restoration quicker than their first.
Also I'm genuinely interested to know what the norm is. Five years on and other than the fact that the car is still going strong I've got no real way of knowing if my own hours were good, bad or indifferent. I did have the advantage of starting with a complete car - albeit a very shagged one, and Series 2 parts are doubtless easier to come by than parts for the earliest cars (despite RHD Series 2s being amongst the rarest ).
#17 Re: OBL = $565k
Hi Simon,
I’m at the end of my total nut and bolt restoration - just under 3.5 years elapsed time. 1,750 hours of my time plus professional services time; 320 hrs body shop, 20hrs AJS diff rebuild, 40hrs engine & carb rebuild and refit, 8 hrs gearbox overhaul, 2 hrs prop overhaul & balance.
As i’m a first timer and learning on the job, I know I took a lot longer than the pro’s to do certain things (rewiring and interior trimming in particular) and I stripped all the paint/underseal back to metal by hand rather than risk baking/dipping/blasting issues, which took what seemed like forever!
Most restorers I contacted at the start talked about 1500 hours as a starting point, condition of body being the main variable.
So at an average £50 per hour, plus parts, plus car purchase price, plus the dreaded vat, I can see where some of the eye watering prices come from.
I had a very limited budget, so had no choice but to do it myself.
#18 Re: OBL = $565k
And you've done a fine job that any pro' shop would be pleased with
#19 Re: OBL = $565k
Thanks Geoff, if I get the rich running sorted out, I’ll be able to get it out to some events for some scrutiny!
#20 Re: OBL = $565k
Thanks, Richard
And as Geoff rightly says, we've seen for ourselves and enjoyed following the exceptional results that those hours of yours have produced.
Highlighting your restoration also makes me realise we should also factor in the fact that the home restorer will also spend additional hours because they will be prepared to spend (make that 'will relish spending') time making each part perfect, whereas the professional restorer will generally have to bear in mind that the customer won't thank them for spending 3 hours at £x per hour perfecting a £10 part and will have to strike some sort of balance as a result.
So if we put a typical full restoration at say 1,500-2,000 hours, it still makes me wonder about claims of 4,000+ hour professional restorations. Yep, a bit of additional challenge with something like the bonnet as David points out, but you're still talking about enough additional hours in which to have restored a second car.....
