#1 Covering material on OTS hood canopy?
Posted: Thu Apr 23, 2020 6:35 pm
1968 OTS series 1.5. What type of material and colour is supposed to be used to cover the hood front canopy and its wooden header rail? And should it have any foam between the metal/wood and the covering material. Any advice welcome.
Mine is currently covered in what i think you would refer to as leathercloth, underneath it is ‘felt’, glued onto the canopy, the same thick felt type material that which was originally under the carpets in my car when i got it, the type that absorbs water like a sponge! My current covering material is biscuit colour Leathercloth to match the rest of the interior, it is not well glued on to the felt and so it is sagging in areas, most noticeable obviously when the soft top is up. The two escutcheons are the only attractive thing about it. I want to replace the covering and looking on Aldridge and BAS websites its not obvious to me what material and colour i should use. The hood is Fawn colour in Mohair, being a beige colour on the inside of the hood cover material.
