Winter storage on axle stands
JerryL770
#1 Winter storage on axle stands
Post by JerryL770 » Fri Nov 06, 2020 3:32 pm
I took my E out for a warm up recently prior to retiring it for the winter. I decided to take the load off the tyres this time and it will allow me to do a few jobs more easily. Are these the right places for my axle stands?
Whilst looking under the front I found this on the bottom of my radiator:
I understood it was a new, uprated item :shock:
Jerome Lunt
#2 Re: Winter storage on axle stands
Post by mgcjag » Fri Nov 06, 2020 3:43 pm
I dont like the position of the jack in the first photo....needs to come forward slightly ....looks ready to slip rearwards........are you thinking of leaving it like this for the winter.....if so all the suspension is on full droop and tbe IRS is hanging on its mounts....personaly i like a nice big block under the center of the IRS.....then the rear axel stands where you have them just as stabilisers if your working on the car......If for winter storage you want the weight off the tyres then chock it front and rear under the wishbones........Steve
JerryL770
#3 Re: Winter storage on axle stands
Post by JerryL770 » Fri Nov 06, 2020 4:44 pm
Good point Steve, I'd forgotten that potential. I will re-mount appropriately. Having taken a squint underneath some more, I found I have no rear bump stops, despite having asked for some to be fitted.
I wonder if there is too little rome with the alloy wheels :scratchheadyellow: though standard tyres.
Jerome Lunt
#4 Re: Winter storage on axle stands
Post by PeterCrespin » Fri Nov 06, 2020 9:44 pm
Looks new to me and it depends what you mean by uprated.
Mich7920
#5 Re: Winter storage on axle stands
Post by Mich7920 » Sat Nov 07, 2020 8:32 am
I don't like the idea of putting the car on jacks for 4 or 5 months.
All the bushs are tightened with the car in static on its wheels. They're going to be in extreme extension during all this time and it's not going to be very good. Look at the angle of the radius arm...
Michel
1965 E Type FHC - On the road - 1963 E Type OTS - Angus Restoration
Gran Torino Sport 1975 - Renault 4cv 1956 - CItroen 15/6 1951 - CItroen Traction 1945
Citroen Coupé docteur 5Hp 1924 - Citroen B12 1926 - Torpedo Sygma 1913
Harley D. 1915 sidecar
#6 Re: Winter storage on axle stands
Post by malcolm » Sat Nov 07, 2020 9:55 am
I've never done this, and my tyres don't seem to have come to any harm. If you're worried about the tyres, you could just jack the car up now and again and turn the wheels
JerryL770
#7 Re: Winter storage on axle stands
Post by JerryL770 » Sat Nov 07, 2020 10:23 am
All good points, thank you. I will drop it down again when below matter is sorted.
Yes, well, I don't really know what the "uprated" meant either. Most likely, I assume, the more fins type. However, I now suspect that it is the original radiator with a replacement core so the top n bottom tanks are originals with some internal corrosion. For the first year I had the car it only had clean water in, till I discovered this and flushed and refilled with proper antifreeze.
So I'm going to take the rad out for repair or replacement. I don't need anything fancy tho. Any recommendations for repairers in the East Midlands?
Jerome Lunt
44DHR
#8 Re: Winter storage on axle stands
Post by 44DHR » Sat Nov 07, 2020 10:47 am
I do take my wheels off in the winter months - usually from October through to March or April the next year. I keep the suspension under some form of compression to ensure they are not hanging in free space at their extremes - especially with the front wishbones which could potentially have the steering rack ball joints at maximum angles.
The front is on one pair of axle stands under the front lower wishbone mounting block - as shown in the topic author’s second photo - but with a second set of axle stands giving a level of support at the outer end of the wishbone near the lower swivel ball joint so the wishbone and steering rack is not hanging at it’s extreme.
At the rear, I jack the car using an alloy and wooden jig under the differential and lower the car onto wooden blocks to rest on the ends of the rear lower wishbones - as near to the alloy hubs as possible without touching the grease nipples under the rear hub.
The other reason that I remove the wheels and tyres during winter is that with the car jacked up, I can access areas under the car.
Cheers,
Dave Rose
1967 Series 1 4.2 FHC
JerryL770
#9 Re: Winter storage on axle stands
Post by JerryL770 » Mon Nov 09, 2020 2:48 pm
Axle stands repositioned.
Better :salute:
Jerome Lunt
Norton
Norway
#10 Re: Winter storage on axle stands
Post by Norton » Wed Nov 11, 2020 6:39 pm
Hi. The tires will not be damaged in any way during winter storage. Longer storage in considerable warmer climate may hurt them. But increase pressure aproximately 50%. If not anything else reduces chanches of ending up standing a longer period severely underinflated.
Harald
tim wood
#11 Re: Winter storage on axle stands
Post by tim wood » Wed Nov 11, 2020 7:48 pm
I’ve used this company in the past for radiator works
https://www.nargroup.com/
Tim
JerryL770
#12 Re: Winter storage on axle stands
Post by JerryL770 » Sat Nov 14, 2020 7:19 am
Tim
Thank you for that Tim. Excellent and fairly local to me.
However, I should have looked closer before commenting because when I did, to investigate further, I found only bright shiney metal. Some radiator fluid must have dripped there from above and caused the staining and apparent rust but when I scraped it, it was clean. So no problem there at all. :bouncyyellow:
Jerome Lunt
dougal
#13 Re: Winter storage on axle stands
Post by dougal » Wed Jan 13, 2021 4:58 pm
You shouldn't really need to do that if you are fitting good quality radials
https://www.longstonetyres.co.uk/classi ... -type.html
You shouldn't get flat spots if you fit the Pirelli or Michelin. If you are really concerned you can also just up the pressure. But a radial by a good brand shouldn't flat spot.
Chain Gang for ever
JerryL770
#14 Re: Winter storage on axle stands
Post by JerryL770 » Thu Jan 14, 2021 9:26 am
That's interesting thank you. I'm on Vredsteins and to be fair they did stay on for the first 2 winters and I did not see/notice any flat spotting. Maybe I'm being over cautious :smile:
Jerome Lunt
