Engine installing S1 4.2p the rear and pu
#1 Engine installing S1 4.2p the rear and pu
Hi after seeing on this forum how to install an engine I found it quite easy even on my own .I jacked up the rear under the suspension drive assembly and put a small pallet under each wheel . then I raised the front just over three feet using the engine hoist then lowered it onto a large piece of timber on two axle stands under the forward jacking points. Then it was just a case of putting the engine and box on a low four wheel trolley and rolling it underneath. Then back to the hoist and carefully lowering the body over the engine . I am keeping the body slightly high so I can get underneath to attach the gearbox mount . As long as you take it slow it is quite easy. Engine back in after 24 years .
S1 4.2 RHD Bryan
#2 Re: Engine installing S1 4.2p the rear and pu
Now that is taking it slowly
#3 Re: Engine installing S1 4.2p the rear and pu
Is the prop shaft in......Steve
#4 Re: Engine installing S1 4.2p the rear and pu
Yep, trying to catch me out eh. This car was stripped completely about 24 years ago (not by me) and also moved storage so quite a few bits gone astray. Bryan
S1 4.2 RHD Bryan
