Forum back room hard work
Topic author - Posts: 3324
#1 Forum back room hard work
It would be easy to think that David (Heuer) spends his day searching for old photos of E Types or taking photos of his nieces en dishabille. Though I envy the latter!
However a recent topic I started in the technical section to give ready reference for how to wire lock bolts has been an example of the daily work he does to keep this forum in good order.
All I had done was plagiarise info from the interweb, David then had to format it all to the forum standard, tidy up some of my headings and generally make it all easier on the eye. He will then probably convert it to pdf to add to the KB and make the topic a sticky. Mine was the easy job, his the more onerous.
Which leads me to say a public thank you, David, for the back room work you do for all our benefits
With gratitude
With gratitude
#2 Re: Forum back room hard work
.....Steve
#3 Re: Forum back room hard work
1950 XK120
1965 S1 E Type DHC
1965 S1 E Type DHC
#4 Re: Forum back room hard work
Much appreciated.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#5 Re: Forum back room hard work
#6 Re: Forum back room hard work
#7 Re: Forum back room hard work
And one french more
Looking for a OTS 4.2 serie 1....! and now have found a fhc xk 140
#8 Re: Forum back room hard work
#9 Re: Forum back room hard work
Michel
#10 Re: Forum back room hard work
Thank you David. You always shed light on the more obscure technical aspects of our cars and my restoration wouldn't have progressed so well without that input.
Yours,
Yours,
Phil P
1965 4.2 FHC
1965 4.2 FHC
#11 Re: Forum back room hard work
Same
Serge
1964 (3.8) FHC
1961 OTS
1964 (3.8) FHC
1961 OTS
#12 Re: Forum back room hard work
Yes very appreciated,here in Canada.
Regards Gerry 62 Ots.
#13 Re: Forum back room hard work
100% - unsung hero....
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#14 Re: Forum back room hard work
the forum is great source information
#15 Re: Forum back room hard work
Many many thanks
Peter {XKE V12HE efi}
XKRS
RR Phantom 3 1937 Sedanca de Ville.
XKRS
#16 Re: Forum back room hard work
David you are a star, Thank you
e type series 3 V12 2+2 1972, BMW iX 2023
