6 cyl engine stand
E600
#1 6 cyl engine stand
Post by E600 » Wed Nov 15, 2023 7:46 pm
Hi, has anyone got an 6 cyl engine stand I can borrow or with charity donation. Looking for the type the secures on a side not the bell housing end. Thanks in anticipation ..Pat
alfazagato
#2 Re: 6 cyl engine stand
Post by alfazagato » Thu Nov 16, 2023 9:55 am
I have a two sided "frame" engine stand which allow the engine to be turned through 360 degrees which is for sale. Easily strong enough for a Jaguar engine and adjustable in width for bigger units. Send me a PM if interested....I am in South West London.
Series 1.5 FHC
E600
#3 Re: 6 cyl engine stand
Post by E600 » Fri Nov 17, 2023 10:47 am
Pm sent.
rfs1957
#4 Re: 6 cyl engine stand
Post by rfs1957 » Mon Nov 20, 2023 12:57 pm
If you were thinking of this type
viewtopic.php?f=3&t=11938&p=139269&hili ... nd#p139269
then the prototype that SNGB used to base their production from is somewhere floating around the UK, and I can probably arrange for you to borrow it.
How long do you need it for ?
E600
#5 Re: 6 cyl engine stand
Post by E600 » Fri Nov 24, 2023 6:54 am
Many thanks, probably a month or so. Where abouts are you, or it and I will collect. Thanks
E600
#6 Re: 6 cyl engine stand
Post by E600 » Mon Nov 27, 2023 10:39 pm
Hi, any update?
rfs1957
#7 Re: 6 cyl engine stand
Post by rfs1957 » Tue Nov 28, 2023 1:01 pm
See my PM.
#8 Re: 6 cyl engine stand
Post by Gfhug » Tue Nov 28, 2023 2:19 pm
Rory, should it become available in 2024 when I hope to tackle my OTS engine I’d be pleased to borrow it for a suitable donation or even buy it to then loan out to others on the forum.
E600
#9 Re: 6 cyl engine stand
Post by E600 » Tue Nov 28, 2023 10:59 pm
Replied via pm
E600
#10 Re: 6 cyl engine stand
Post by E600 » Wed Nov 29, 2023 8:15 pm
Rory. If you pm you telephone number I will call you.
Tia
E600
#11 Re: 6 cyl engine stand
Post by E600 » Thu Nov 30, 2023 7:54 pm
Any update
rfs1957
#12 Re: 6 cyl engine stand
Post by rfs1957 » Thu Nov 30, 2023 9:46 pm
Message sent just now.
E600
#13 Re: 6 cyl engine stand
Post by E600 » Fri Dec 01, 2023 1:47 am
Nothing in pm’s?
E600
#14 Re: 6 cyl engine stand
Post by E600 » Wed Dec 13, 2023 9:51 pm
Made an engine cradle adapter. It’s not a new idea but changed slightly in that I’ve used 4 small plates to bolt the engine cradle bracket as I didn’t have any 60 mm thick walled pipe.
rfs1957
#15 Re: 6 cyl engine stand
Post by rfs1957 » Thu Dec 14, 2023 8:52 am
That's a very good bit of lateral thinking, Pat.
:drinkingcheers:
I wish it had been my idea, it's a much better approach to the problem.
E600
#16 Re: 6 cyl engine stand
Post by E600 » Fri Dec 15, 2023 12:43 am
I’m but standing on the shoulders of giants. Credit must go to the originator.
E600
#17 Re: 6 cyl engine stand
Post by E600 » Sun Jan 14, 2024 12:19 am
Now being used in earnest
