Home made valve spring compressor
Iansparky
#1 Home made valve spring compressor
Post by Iansparky » Thu Apr 04, 2024 11:02 am
Hi All
This is what I made for removing the valves from my head, I 1st made the wooden board as per the Bentley manual for the head to sit on, then on my lathe i bored a 40mm length of 25mm steel to 30mm deep, threaded the solid end m8, then after milling the slots i assembled it as shown on the lengths of steel. It works well if a little slow, a 13mm ratchet spanner would help but it does the job.
Thanks for looking
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
tim wood
#2 Re: Home made valve spring compressor
Post by tim wood » Thu Apr 04, 2024 7:22 pm
Looks good, well done !!
