Stick on number plate
johnben
#1 Stick on number plate
Post by johnben » Sat Nov 10, 2012 8:02 am
Anyone got a good source for a stick on number plate? there is just too much choice on the internet.
vacbag
#2 Stick on Number plate
Post by vacbag » Sat Nov 10, 2012 9:50 am
John.
I went to my local vinyl sign maker and got 2 for ?10 and a free applicator.
Steve.
Steve. Series 2 OTS.
ChrisC
Post by ChrisC » Tue Nov 13, 2012 9:25 am
and a tip for applying it... cover the bonnet area and back of the plate with weak soapy water and then apply the plate into position. The soapy water allows you some flexibility to adjust the placement / peal re-apply it.
You then squeegee the water out and leave it to dry - trust me it works :)
1964 FHC 4.2
johnben
#4 Stick on number plate
Post by johnben » Thu Nov 15, 2012 7:22 pm
ChrisC wrote:and a tip for applying it... cover the bonnet area and back of the plate with weak soapy water and then apply the plate into position. The soapy water allows you some flexibility to adjust the placement / peal re-apply it.
Hi Chris. you use this method for self adhesive number plates? I thought it was only used for the transfer type.
rfs1957
Post by rfs1957 » Fri Nov 16, 2012 8:24 am
Works perfectly for all adhesive decals ; just requires dexterity to chase all the bubbles out, but stops larger surfaces 'grabbing' and becoming prematurely stuck. Get a squeegee with a straight edge, a credit-card is quite good for small surfaces.
Post by Heuer » Fri Nov 16, 2012 10:04 am
I used spray on domestic window cleaner, usually green in colour variety, as it evaporates quicker and it less messy to use than soap and water.
johnben
#7 Stick on number plate
Post by johnben » Sun Nov 18, 2012 6:49 am
Thanks for the tips.
