Luggage board sliding catches
#1 Luggage board sliding catches
Post by Gfhug » Fri Nov 21, 2014 4:44 pm
The sliding catches that hold the luggage board up in my FHC keep sliding to the open position. Should there be a spring or some other means to hold the catch in the closed/open position?
Taking the catch off the board there are two small deeper cut outs (detents?) in the slot the catch slides along, almost as though there should be a spring to hold the catch in the open or closed positions.
Simon P
Post by Simon P » Fri Nov 21, 2014 5:46 pm
Evening, Geoff
No springs - it should just slide back and forth. Not sure how it manages to keep sliding open though as effectively that's against gravity. Is it shaking open perhaps? If the 90-degree tab on the bracket that the lock slides into isn't snug against the board when the board is raised it can happen. A few taps on the back of the tab so that the board rests securely ought to do the trick if so.
Hope this helps
1969 S2 FHC - 1R20258
Post by Gfhug » Fri Nov 21, 2014 6:19 pm
Hi Simon, how are things?
Thanks, it must be shaking loose and can't push that tab any further without it catching the board as it goes up and down. Will work at getting the geometry a bit better over the winter, don't expect to have anything too heavy in the back that would wish to migrate forward under braking.
Simon P
Post by Simon P » Fri Nov 21, 2014 6:43 pm
Ah - my cr*p explanation I think :oops: It's the part of the 90-degree bracket that the board rests against that needs to be adjusted so that it's snug against the back of the board. Effectively the combination of the sliding tab and that bit of the bracket should lock the board in place - any residual movement means the bracket needs a bit of gentle persuasion, otherwise the board will start to shake free.
Things are good, thanks. I spent the day watching my Lancia 'having its bits waxed' :wink: [I treated its undersides to a professional coating of industrial strength Waxoyl. Should see it through for a good few years more!]
Post by Gfhug » Sun Nov 23, 2014 9:29 am
Thanks Simon, yes it effectively clamps it in place like a vice. Now I shall look again at mine and fettle a bit.
rossbraithwaite
Post by rossbraithwaite » Sun Dec 14, 2014 5:09 pm
Hi Geoff,
My luggage board catches have exactly the same problem of opening themselves. How did you get on curing it?
Thanks, Ross
'67 S1.5 FHC, manual, maroon with black interior. Originally exported to Arizona but 'repatriated' in '89. Since converted to RHD and triple SUs.
1954Etype
Post by 1954Etype » Sun Dec 14, 2014 5:23 pm
There should be a rubber buffer on the right angle bracket - that compresses a little to hold the catch against the bracket. There is no sliding adjustment on the bracket as they are pop riveted to the wheelarch.
Angus 67 FHC 1E33656
61 OTS 875047
Post by Gfhug » Mon Dec 15, 2014 6:43 pm
Ross, as 1954Etype says there should be a rubber buffer. Both were missing from mine. Before learning that I had had to refit the right angle bracket due to it being loose, so ended up bending it so it made a firm hold on the board. I may find some rubber to make a buffer and re-do the job another day.
Hope this helps
scarr27
#9 Re: Luggage board sliding catches
Post by scarr27 » Tue Mar 16, 2021 10:28 am
Bit late but might be of use.
The sliding bolts do have a detent.
Remove the bolt assembly from the board. Unscrew the knurled knob and the assembly comes apart. There is a tiny spring and a ball bearing that live in a hole in the slide. Your spring may have become damaged.
I only discovered this when getting it re-chromed.
This is on a October 1962 3.8 FHC.
Sean
3.8 62 - FHC
