New Reproduction Parts for E-Type's
#21 Re: New Reproduction Parts for E-Type's
Post by Heuer » Fri Jun 17, 2016 11:27 am
Richard Smith has been in touch:
"A new item that I’ve done its BD21066K which is the rear hatch release mechanism return spring and pivot rivet":
Cheers Richard.
Richard M Smith
R M and J Smith Ltd
P.O.Box 249
Nantwich
Cheshire
CW5 9AR
Tel: 01270 780954
rmjsmithltd@gmail.com
S1 OTS OSB; S1 FHC ODB
#22 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Jul 06, 2016 4:07 pm
Richard Smith now has the complete S1 heater controls available:
Richard M Smith
R M and J Smith Ltd
P.O.Box 249
Nantwich
Cheshire
CW5 9AR
Tel: 01270 780954
#23 Re: New Reproduction Parts for E-Type's
Post by Heuer » Sat Aug 20, 2016 10:43 am
More new parts being produced by Richard Smith:
C11820/7 Palnut. This is the locknut securing the nut holding the steering wheel to the steering column. Fits all E Types and is most important from a safety point of view. Not been available for a long time and is either missing or ineffective through wear on most cars.
Richard has also made made part BD13642/5 which is the special chrome screw attaching the sunvisors to all FHC and 2+2 cars. It also attaches the interior mirror on all Series 1. The screw is pointed and has the correct slotted raised counter sunk head.
As usual you can order these directly from Richard:
Richard M Smith
R M and J Smith Ltd
P.O.Box 249
Nantwich
Cheshire
CW5 9AR
Tel: 01270 780954
#24 Re: New Reproduction Parts for E-Type's
Post by Heuer » Mon Oct 17, 2016 11:38 am
Just received this:
"Hi David/Angus,
I hope you are both well? I wanted to let you know that after our visit together at the factory where we discussed heated and antenna screens we have had a look into wiring both into the same screen after some requests from your forum members. I'm glad to say that we are now able to offer a screen for both FHC/DHC with both wired. So far we ran only the DHC parts through (my code HT0120 CLHA).
Also regarding the Classic show, well be there on Stand 345 in Hall 5 if your there please pop over and say hello, we'll have the E-Type frame set up with our glasses on it and one of these screens to take a look at.
Nick Gardiner
General Manager
Pilkington Automotive Queenborough
+441795596103
+447969087514
nick.gardiner@nsg.com"
If you are interested in a heated antenna screen please contact Nick Gardiner.
#25 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Oct 19, 2016 3:29 pm
Richard Smith has been in contact:
"Hi David
Please see attached image of 2 new items I have made:
BD24411 Chrome escutcheon for safety harness attachment points at rear quarters
BD24484 special screw for tchrome escutcheon.
They fit all Series 1 FHC, except early coupes
Richard"
Contact Richard directly if you need these.
#26 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Nov 30, 2016 11:56 am
From Richard Smith:
"Please see photo of new item I have - part number BD15886/5, the 5/8” hose clamp. I’ve made them exactly as original with the correct 5/8” stamping.Cheers Richard."
A word of warning - check your hose diameter as these will only tighten up on 5/8" (15.88mm) OD hoses. Most replacements are 15mm so you could get leaks!
#27 Re: New Reproduction Parts for E-Type's
Post by Heuer » Thu Feb 23, 2017 11:07 am
From Richard Smith:
"Hi David, hope you’re fit and well. I’ve just made the correct 3.8 grab handle BD20636 (LHD) and BD20637 (RHD) - the leather is hand stitched as original. Cheers, Richard."
Contact Richard directly if you want one.
R M and J Smith Ltd
P.O.Box 249
Nantwich
Cheshire
CW5 9AR
Tel: 01270 780954
#28 Re: New Reproduction Parts for E-Type's
Post by Heuer » Tue May 02, 2017 1:17 pm
Just received this from Julian:
"Hi David,
Attached photo of new SNGB air filter grommet C175465 in silicone. Designed to improve durability and now in stock.
We have a number of other similar items coming in more durable format - including ball joint/TRE gaiters. Will update you on those as and when
Best
Julian"
Contact SNGB directly if you want one.
#29 Re: New Reproduction Parts for E-Type's
Post by Heuer » Thu May 11, 2017 4:21 pm
"Hi David,
Control your excitement...
The E-type V12 catalogue has just landed. We are putting away now and will be dispatching from Monday. 300 pages with loads of new pictures and content.
Best regards
Julian"
Contact SNGB to request your free copy.
#30 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed May 17, 2017 3:19 pm
Butlers number plate light chrome bezels are now available:
"Hi Guys.
Just like to say I manufacture these Butlers Chrome surrounds. They are certainly not made in China. They are made by hand so they are the same as the original items. As with all parts I am manufacturing (all of the etype hardtop chrome trims, reproduction hardtops, etc) the aim is to manufacture high quality parts that are not available. A huge amount of development has gone into getting these parts 100% correct.
If they were made in China then the price would be far less........... but so would the quality.
Tim"
£300 + £15 p&p from Tim Goldthorp at Classic Quality (Parts) Limited of Ludlow http://www.classicquality.co.uk/
They were fitted to approximately the first 1,250 cars (Oct/Nov 1961) and everything we know about them can be found here: viewtopic.php?p=35522#p35522
SNGB sell the complete number plate assembly (not marked Butlers or Lucas) for £25 each if you need them to complete a set of Butlers lights.
#31 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed May 24, 2017 10:46 am
Marek has been in touch to say he is now producing LED reverse lights:
"It consists of a pcb with 200 high brightness LEDs. The pattern is circular and follows the circular pattern of the lens housing."
Not only will it work as a very bright reverse light but it also houses red LED's which means it can be used as a third brake light. Simply connect the third wire to your brake light circuit. You can also add the option to use it as a high intensity 'fog' light with the addition of a switch and a length of wire. I hope to be doing a full test shortly and will post a review.
If you are interested please PM MarekH for price and availability.
#32 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Jun 14, 2017 12:08 pm
Welsh Enterprises are now offering the 1961-1965 fluted side light lenses, albeit only in clear, at $89.95/pair.
http://www.welshent.com/product_info.php?sku=8616E
#33 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Jun 21, 2017 10:06 pm
Richard has been at it again and produced some more, previously unobtainable, parts:
Part #C16753 - the metal elbow oil return pipe on the side of the sump which fits all 6 cyl E-Type's:
Part numbers #C18510 and #C18571 - the heater control cable mounting bracket assembly.
Contact Richard directly if you need these items: Tel: 01270 780954 rmjsmithltd@gmail.com
#34 Re: New Reproduction Parts for E-Type's
Post by Heuer » Sat Jul 08, 2017 10:14 am
C30112 which is the correct dipstick fitted to all S2 and late S1.5 E-Type's. It is made from the correct half round wire and chromed.
Cheers Richard.
Richard M.Smith,
R.M & J.Smith Ltd.,
P.O.Box 249,Nantwich,Cheshire,
United Kingdom.
Tel.01270 780954
#35 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Aug 09, 2017 1:38 pm
"SNG Barratt is pleased to announce the modern and robust version of the warning lamp module, which gives you the authentic appearance of the original with the benefits of modern electronics inside with increased protection. The updated version provides both reliability and durability. Retailing at £39.60 /$52.80 /FR €45.54 / NL €45.92 /DE €45.16 Part number BMK1092JU"
#36 Re: New Reproduction Parts for E-Type's
Post by Heuer » Mon Aug 21, 2017 12:16 pm
Richard Smith has produced this for the S2 dipstick, which he also reproduces:
Contact Richard if you want one.
R.M & J.Smith Ltd.,
United Kingdom.
Tel.01270 780954
#37 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Nov 01, 2017 1:37 pm
Angus has decided to address the problem all 6 cylinder owners face with oil dripping from the hose connecting the sump to the oil cleaner. The issue has always been that the outlets on these parts are of different diameters yet the the hose #C15949 is linear with the same diameter along its length - so tight on one end loose on the other! And no matter how much you tighten up the clips there always seems to be a leak. The solution is to have a tapered hose, in this case manufactured from cotton reinforced silicone:
Angus reports that after fitting one to his car he has not had even a single drip of oil from either pipe after 1,200 miles of high speed motoring! They are available from Moss Jaguar at £22 each including VAT, UK post and packing.
mark10337
Switzerland
#38 Re: New Reproduction Parts for E-Type's
Post by mark10337 » Wed Nov 01, 2017 10:12 pm
For our friends across the pond, also available from classicjaguar.com
http://classicjaguar.com/cjparts/sol.php
-Mark
#39 Re: New Reproduction Parts for E-Type's
Post by Heuer » Thu Nov 02, 2017 1:15 pm
Indeed although I do like the less bling approach Angus has taken, using cotton wrapped matt silicone rather than the glossy stuff that seems to be favoured by rice-rocket owners.
#40 Re: New Reproduction Parts for E-Type's
Post by Heuer » Mon Nov 27, 2017 2:47 pm
Simon Wood (288gto) has just sent me this:
Steering housing seal retainer #BD19710
"Just a quick message to say that disappointed with vendor attempts at reproducing this part I had tooling made that hopefully gives a better pressing. I've also had the part made from titanium which closer resembles the cadmium plating rather than the shiny bright zinc of the reproduction ones. I know this part is barely seen but others might be interested. For reference, mine on the left, original middle and repro on the right.
Regards Simon"
PM Simon for more information.
