Prototype????
dal2.0litrefrogeye
#1 Prototype????
Post by dal2.0litrefrogeye » Tue Jul 17, 2018 1:26 pm
I've only heard about this once before , and the guy I heard it from can tell a tale or two , so I poo pooed it a bit but in the photo of the lightweight E the inlet is on the exhaust side and I assume the exhaust is the other ?????? Anyone else heard or know about this ???? I may owe "my mate" an apology :banghead:
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
cactusman
#2 Re: Prototype????
Post by cactusman » Tue Jul 17, 2018 3:15 pm
Me suspect the image was printed from a negative and the negative was put in the machine that took the print off the wrong way up...easily done. Result would be a reversed image where left is right and right is left I think..although does not explain battery location but maybe light weight cars do have the battery on the inlet side?
#3 Re: Prototype????
Post by Heuer » Tue Jul 17, 2018 3:29 pm
Yes, a reversed image. LWE's had the battery under the carbs as the exhaust side had the dry sump oil tank next to it.
S1 OTS OSB; S1 FHC ODB
#4 Re: Prototype????
Post by Gfhug » Tue Jul 17, 2018 4:15 pm
Or it might have been a version for the Australian market? :lol:
Geoff Green
#5 Re: Prototype????
Post by Geoff Green » Wed Jul 18, 2018 12:56 am
I think it was built on Opposite Day.
dal2.0litrefrogeye
#6 Re: Prototype????
Post by dal2.0litrefrogeye » Wed Jul 18, 2018 9:25 am
Turns out the car also had 1 forward gear and 4 reverse :seeingstars:
cactusman
#7 Re: Prototype????
Post by cactusman » Wed Jul 18, 2018 12:02 pm
I wonder if the fuel tank fills as you drive? :bigrin: :bigrin: :bigrin:
#8 Re: Prototype????
Post by Series1 Stu » Thu Jul 19, 2018 10:40 pm
That's just like the Northern Ireland green energy incentive!
Two questions.
First, aren't those D Type wheels?
Second, what are those headlight bowls? They don't seem to be the same as the Series 1 items.
'78 Land Rover Series 3 109
#9 Re: Prototype????
Post by PeterCrespin » Sat Jul 21, 2018 6:49 am
Yes, Dunlop spun alloy centres riveted to rolled alloy rims. The LWE peg-drive setup is very slightly different to the D, with the spinners not being truly interchangeable due to a different rear face.
