What is this Red/Yellow cable?
Jeremy
#1 What is this Red/Yellow cable?
Post by Jeremy » Sat Jan 20, 2018 6:23 pm
Help please.... I'm fitting new harnesses, and there's a red and yellow cable emerging at the dash centre from the engine bay harness that i can't find in the wiring diagram. On the old harness it wasn't connected to anything and connector had been taped over. Any suggestions? Many thanks.
Jeremy
1967 S1 4.2 FHC
#2 Re: What is this Red/Yellow cable?
Post by Heuer » Sat Jan 20, 2018 7:28 pm
It is for the (optional) fog/spot lights which were never actual offered as an option by Jaguar. It would have connected to the four position light switch which later cars had.
S1 OTS OSB; S1 FHC ODB
Jeremy
#3 Re: What is this Red/Yellow cable?
Post by Jeremy » Sat Jan 20, 2018 9:06 pm
Thanks David! Interesting. Odd that Jaguar went on incorporating it into the harness, when leaving it out would have saved a couple of pennies.
Jeremy
1967 S1 4.2 FHC
andrewh
#4 Re: What is this Red/Yellow cable?
Post by andrewh » Sun Jan 21, 2018 1:05 am
When I wired my 3.8 it was not in my original loom so reckon it's there to streamline the new looms for cars with fogs. Proved very useful for me as I needed power through bonnet plug for daytime running lights and had this feed already bound in the loom
1962 3.8 Series One FHC
ralphr1780
#5 Re: What is this Red/Yellow cable?
Post by ralphr1780 » Sun Jan 21, 2018 9:21 am
I am now replacing the 3 post switch with a 4 post one, for a quite interesting feature. On this 4 post the fog position activates fogs but cuts off headlamps, sidelights demain on... Will détail in a différent post.
Ralph
'69 OTS + '62 OTS - Belgium
