S1 4.2 Gearbox Advice
gts2
#21 Re: S1 4.2 Gearbox Advice
Post by gts2 » Mon May 22, 2017 5:28 am
@ Bill/angelw
please check your private messages.
On Saturday I sent you an enquiry regarding the modified rear bearing I would require very urgently...
'62 3.8 OTS, '64 3.8 FHC
Tails733
#22 Re: S1 4.2 Gearbox Advice
Post by Tails733 » Sat May 12, 2018 9:49 pm
https://www.scparts.co.uk/sc_en/ball-be ... 17859.html
Bloody expensive but might be what your after?
angelw
#23 Re: S1 4.2 Gearbox Advice
Post by angelw » Sat May 12, 2018 10:22 pm
Hello Tails733,
Wrong bearing style. The correct bearing has minimal radius (virtually none) between the face and bore of the Internal Race of the the cir-clip end. The bearing supplied by all the suppliers have a large radius that results in minimal contact between the face of the inner race and the Oil Pump Drive collar.
Hugo
#24 Re: S1 4.2 Gearbox Advice
Post by Hugo » Sat May 12, 2018 10:49 pm
Bearing prices are funny - a while ago I rebuilt a Bristol diff.; the 'correct' crown wheel/diff bearings were listed at £2,000 each (yes two thousand!). I bought a pair of bearings 1mm wider for about twenty quid each. Fitted perfectly under the castellated adjuster nuts, and the whole ass.y fitted into the axle casing no problem.
#25 Re: S1 4.2 Gearbox Advice
Post by christopher storey » Sun May 13, 2018 6:49 am
Not only the wrong style, but for the wrong gearbox! The all-synchro is quite different from the Moss Box
angelw
#26 Re: S1 4.2 Gearbox Advice
Post by angelw » Sun May 13, 2018 10:45 am
Hello Christopher,
Actually, the bearing is the same for both gearboxes.
I have now sourced a bearing that is about 95% correct in terms of the radius (or lack thereof) of the inner race, at the cir-clip end of the bearing. They are without the cir-clip groove, which I then machine.
