@ Bill/angelw
please check your private messages.
On Saturday I sent you an enquiry regarding the modified rear bearing I would require very urgently...
S1 4.2 Gearbox Advice
#22 Re: S1 4.2 Gearbox Advice
https://www.scparts.co.uk/sc_en/ball-be ... 17859.html
Bloody expensive but might be what your after?
#23 Re: S1 4.2 Gearbox Advice
Tails733 Wrote:
Wrong bearing style. The correct bearing has minimal radius (virtually none) between the face and bore of the Internal Race of the the cir-clip end. The bearing supplied by all the suppliers have a large radius that results in minimal contact between the face of the inner race and the Oil Pump Drive collar.
Hello Tails733,https://www.scparts.co.uk/sc_en/ball-be ... 17859.html
#24 Re: S1 4.2 Gearbox Advice
Bearing prices are funny - a while ago I rebuilt a Bristol diff.; the 'correct' crown wheel/diff bearings were listed at £2,000 each (yes two thousand!). I bought a pair of bearings 1mm wider for about twenty quid each. Fitted perfectly under the castellated adjuster nuts, and the whole ass.y fitted into the axle casing no problem.
#25 Re: S1 4.2 Gearbox Advice
Not only the wrong style, but for the wrong gearbox! The all-synchro is quite different from the Moss BoxTails733 wrote: ↑Sat May 12, 2018 9:49 pmhttps://www.scparts.co.uk/sc_en/ball-be ... 17859.html
#26 Re: S1 4.2 Gearbox Advice
Christopher Wrote:
Actually, the bearing is the same for both gearboxes.
I have now sourced a bearing that is about 95% correct in terms of the radius (or lack thereof) of the inner race, at the cir-clip end of the bearing. They are without the cir-clip groove, which I then machine.
Hello Christopher,Not only the wrong style, but for the wrong gearbox! The all-synchro is quite different from the Moss Box
