I am changing the Harmonic Damper for a new unit as the rubber was breaking up.
I need to clean the thread up in the Crankshaft for the bolt.
Does any one know the thread size so I can run a tap into it to clean the threads up.
The old bolt was knackered so a new one has been purchased and I don't want to strip the threads on the bolt...
E Type 3.8 Litre, 1961. Crankshaft Damper bolt thread size ?
#1 E Type 3.8 Litre, 1961. Crankshaft Damper bolt thread size ?
Clive
August 1961 Flat floor ots
#2 Re: E Type 3.8 Litre, 1961. Crankshaft Damper bolt thread size ?
3/4" UNF 16tpi.
Same thread as rear driveshaft into hub.
#3 Re: E Type 3.8 Litre, 1961. Crankshaft Damper bolt thread size ?
Your a star, thank you so much...
Clive
