I've been trying to work out what thread the bolts holding the bell housing to the Moss box are.
The head is best fitted by a 3/8 W socket.
The bolt is 18 tpi and matches my 5/16 W thread gauge perfectly BUT it's 0.406" (13/32) in diameter, not 5/16.
I've exhausted my patience with internet searching.
Anorak time; bolt size
#1 Anorak time; bolt size
#2 Re: Anorak time; bolt size
Not sure if this will help Andrew...but they are listed as FB. 107/13D in the parts catalogue....and C9859 / C9860
Jonathan
Jonathan
#3 Re: Anorak time; bolt size
Yes, I found that. All NLA and I can't decipher all of the long bolt code.265bhp wrote:Not sure if this will help Andrew...but they are listed as FB. 107/13D in the parts catalogue....and C9859 / C9860
Jonathan
F = Fine thread
B = Bolt
1= Hex head
07 is not a valid diameter code for a bolt
13 = 1 5/8" length which is right
D not a valid code position
I have all the bolts I need but I'm interested to know what thread it is...
#4 Re: Anorak time; bolt size
Couldn't be a Helicoil thread I suppose?
As I'm sure you know, most BSW threads are the same pitch as UNC (although the profile is slightly different).
You say a 3/8" BSW wrench fits the head. That's actually a bit ambiguous - originally a 3/8" WW spanner size was the same as a 7/16" BSF, and many wrenches had dual markings. Whitworth nuts & bolts had bigger heads than their BSF counterparts. In the old days, any time you heard a mechanic asking for a "quarter Whit" spanner, you can be pretty sure what he really wanted was a 5/16" BSF, although that is academic as they're the same size.
Then, during WWII I think it was, they reduced the size of the heads on WW nuts & bolts to make them the same as BSF in order to save metal.
The size across flats on both BSF and WW is some weird fraction - no idea where they got it from.
But to get back to your bolts, if it's any consolation I haven't a clue either, other than my original suggestion.
