Gearbox oil,leak ( moved from Series 3 forum)
#1 Gearbox oil,leak ( moved from Series 3 forum)
I have noticed quite a bad oil leak from my '71 auto gearbox, would I be better going to an Auto gearbox specialist, or an E-type specialist?? Any recommendations in the southeast England area?
S3 2+2 1971
Aston V8 Vantage 2006
Caterham Supersprint 1.7 1989
Jeep Wrangler TJ
S3 2+2 1971
Jeep Wrangler TJ
#2 Re: Gearbox oil,leak ( moved from Series 3 forum)
Is it worth asking E Type UK (see top right of the banner above)? They might be able to point you to someone.
#3 Re: Gearbox oil,leak ( moved from Series 3 forum)
I think an E Type specialist would only farm the work out to a gearbox specialist and add their markup.
I suppose it depends on whether you're removing the gearbox yourself or not.
'78 Land Rover Series 3 109
#4 Re: Gearbox oil,leak ( moved from Series 3 forum)
They are renowned for leaking from the sump gasket. Its a simple job to cure. Might be worth getting it in the air to check.
#5 Re: Gearbox oil,leak ( moved from Series 3 forum)
You know what, I'm actually going to have a look myself, how hard can it be?
S3 2+2 1971
Jeep Wrangler TJ
S3 2+2 1971
Jeep Wrangler TJ
#6 Re: Gearbox oil,leak ( moved from Series 3 forum)
If you've got a decent socket set, plenty of patience and don't mind the odd drop of ATF in your face, then it's easy enough. At least, until you start delving into the depths of the gearbox.
Good luck.
Good luck.
#7 Re: Gearbox oil,leak ( moved from Series 3 forum)
Hi,Rob Gill here.
can you see what part of the gearbox oil is coming from?
v12 etype 2+2
#8 Re: Gearbox oil,leak ( moved from Series 3 forum)
I'm looking at getting a means of getting it in the air so I can have a proper look around
S3 2+2 1971
Jeep Wrangler TJ
S3 2+2 1971
Jeep Wrangler TJ
