Hi all,
I have an imported series 1.5 fitted with Strombergs and using a series2 type cooling system.
I can also have a set of triple SUs on a 3.8 manifold. It can fit these and sort the throttle connections and the issue of extra core plugs needed at the head joint but the 3.8 manifold has 2 large water inlets whereas the radiator only has the 1 connection.
Has anyone done this before and what are the secrets?
If all else fails I can sell my cleaned and blasted 3.8 manifolds and buy a 4.2 but would rathe not at this stage
Assistance appreciated
Tim
3.8 SU manifold on 4.2 series 2 - water connections
#1 3.8 SU manifold on 4.2 series 2 - water connections
#2 Re: 3.8 SU manifold on 4.2 series 2 - water connections
Hi Tim,
There should only be 1 large outlet which is the thermo housing. The other outlet on the water rail is small and that's part of the bypass circuit which connects via a right angle hose to the top of the water pump. On the series 1.5/2, the factory returned to the superior 3.8 type bypass circuit (along with an improved thermo housing) as IMO, the series 1 4.2 was not a very good design.
There is an excellent thread somewhere on this forum re: modified thermo housings to suit a proper sleeve type thermostats.
Doug
Doug
Doug
'67 ots
'67 ots
#3 Re: 3.8 SU manifold on 4.2 series 2 - water connections
Thanks Doug, very much appreciated. I,ll have a look later. Hopefully that’s sorted it.
Tim
Tim
#4 Re: 3.8 SU manifold on 4.2 series 2 - water connections
Tim, if it can be of help I can gladly take couple of pics of the same setup on my S1 3.8.
Ralph
'69 OTS + '62 OTS - Belgium
