How to install the scoops ?
a) install diaphragm panel (because you have to set 4 bolts to the wing flange next now),
then fiddle scoop in through the lamp hole, curse, scratch, and hopefully it‘ll fit ?
b) fit scoop to diaphragm panel, install as a unit, but how to bolt diaphragm to wing flange ?
Carsten
How to install bonnet sugar scoops ?
#1 How to install bonnet sugar scoops ?
#2 Re: How to install bonnet sugar scoops ?
Carsten,
Good Question ;-)
I dont know but I suspect it is a) install diaphragms and bolt up tight, then insert the scoops through light holes !
isnt there a rubber strip that goes onto the scoops also ?
Good Question ;-)
#3 Re: How to install bonnet sugar scoops ?
Yes there is. And I thought they would be a tight fit to the bonnet - which they do not. There‘s some air gap around their edge.
And yes, through the light holes seems to be the correct way.
Carsten
Carsten
#4 Re: How to install bonnet sugar scoops ?
Yes through the light hole, it’s like one of those magic puzzles!
