Koolmat 2018
ysmalkie
Poland
#21 Re: koolmat 2018
Post by ysmalkie » Fri Mar 30, 2018 7:42 pm
David, the Wikipedia page you mentioned contains the R value of Aerogel - Pyrogel same product.
It's 10.
I guess the higher value the better.
Tadek
Heuer wrote:
Thu Mar 29, 2018 9:52 am
Koolmat being an American company use 'R' values for resistance to heat flow, which is the ratio of the temperature difference across an insulator and the heat flux (heat transfer per unit area): https://en.wikipedia.org/wiki/R-value_(insulation)
The standard 'R' value for Koolmat is 1.6. Many companies (e.g. Dynamat) are reluctant to publish figures and very careful not to claim anything about heat insulation properties. You will need to find the R value of Pyrogel to make a comparison.
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#22 Re: Koolmat 2018
Post by Heuer » Sat Mar 31, 2018 7:05 am
Indeed, that makes it about six times more effective as a heat barrier than Koolmat. Not sure you would need that level of insulation in the E-type though given the cabin in mind never gets warm from engine heat. You then need to consider the compromises of using Aerogel - thickness, resistance to abrasion, water resistance etc.
S1 OTS OSB; S1 FHC ODB
ysmalkie
Poland
#23 Re: Koolmat 2018
Post by ysmalkie » Sat Mar 31, 2018 5:54 pm
Of course, though it comes in 5mm and 10mm thicknesses, so there are options.
And do not be fooled - there are disadvantages to it, too. It's fibreglass type material, so you have to seal (paint it) it properly.
Tadek
Tadek
Jaguar XK120 OTS
derickreid
#24 Re: Koolmat 2018
Post by derickreid » Thu Jun 28, 2018 9:17 pm
Unfortunately, Koolmat from the suppliers link in this thread, is not shipping to Europe because 'its complicated'
A shame, so it looks like dynamat with a layer of dynaliner will have to do.
1971 Series 2 + 2 FHC matching numbers. Full restoration.
Derick Reid
#25 Re: Koolmat 2018
Post by rswaffie » Thu Jun 28, 2018 9:41 pm
That’s just what I’ve been fitting!
[url=https://postimages.org/]Image
[/url]
derickreid
#26 Re: Koolmat 2018
Post by derickreid » Mon Aug 13, 2018 2:38 pm
That looks fantastic. What thickness of the dynamats would you recommend?
Derick Reid
JJC
#27 Re: Koolmat 2018
Post by JJC » Mon Aug 13, 2018 6:51 pm
Hi. Have had this stuff in my '73 OTS for years. I have had the car since new, and I can tell you it makes very, if any difference at all. None that can be noticed , anyway. As for noise, in a top down car ???? Not really a concern. If its that hot out, put the top up, and turn on the a/c !! That works every time !!!
Happy motoring !
JC
#28 Re: Koolmat 2018
Post by rswaffie » Mon Aug 13, 2018 7:54 pm
Hi Derick,
I used 2mm Silent Coat sound/vibration layer. On top of that, 6mm Dodo Liner heat insulation. I used a third product on the outer firewall/bulkhead/gearbox tunnel that is designed to reflect heat. I can’t recall what it was called at the moment though.
gmunro
#29 Re: Koolmat 2018
Post by gmunro » Wed Feb 13, 2019 11:26 pm
Hi Gents. A very interesting topic discussion and it seems that the best way to go is to buy in bulk and cut out the panels yourself. I have seen the "pattern" diagram but my question is - is the pattern a true to size pattern, i.e. do you place it onto the koolmat, draw around the pattern and then cut it out, or is the pattern a guide only as to general shape leaving you to do all the measurements for the individual panels?
Many thanks for your advice. Yours aye,
George
1967 Series 1 OTS
Jeremy
#30 Re: Koolmat 2018
Post by Jeremy » Thu Feb 14, 2019 9:00 am
I would treat any diagram as a guide only. I used brown paper and carefully made up and fitted the paper templates first. The only way to get it to fit accurately in my view. Esp over the gearbox/tunnel.
Jeremy
1967 S1 4.2 FHC
AshM
#31 Re: Koolmat 2018
Post by AshM » Thu Feb 14, 2019 12:57 pm
Jumping on this post string if I may.
I would like to line the underside of my gearbox tunnel before replacing engine to reduce heat into the car. Any recent recommendations?
thanks
Ash
Series 2 FHC 1970
1R 20607
Jeremy
#32 Re: Koolmat 2018
Post by Jeremy » Thu Feb 14, 2019 1:10 pm
Ash,
Zircoflex. The thin one. It's reflective (so deals with radiant heat only) and self adhesive. Easy to mould to the contours. See Chris Vine's blog for full details.
Jeremy
1967 S1 4.2 FHC
#33 Re: Koolmat 2018
Post by rswaffie » Thu Feb 14, 2019 1:24 pm
+1 Zircoflex.
AshM
#34 Re: Koolmat 2018
Post by AshM » Thu Feb 14, 2019 2:43 pm
Thanks for replies - on the case!
Ash
Series 2 FHC 1970
1R 20607
#35 Re: Koolmat 2018
Post by Heuer » Thu Feb 14, 2019 6:42 pm
Also don't forget to use a sheet of foam between the gearbox and top cover.
AshM
#36 Re: Koolmat 2018
Post by AshM » Fri Feb 15, 2019 6:01 pm
Yep - thanks David.
I have a new one from SNGB currently taking up space in one of our spare bedrooms with boxes and boxes and boxes of other parts. All awaiting fitting - and I am only doing from bulkhead forward!
Goodness knows what you guys do who have restored the lot in one go.
My fear is the workshop may become my permanent address too if the boxes don't stop arriving.
cheers
Ash
Series 2 FHC 1970
1R 20607
