#1 Where to fit those 2 guys ?
Posted: Fri Mar 30, 2018 6:31 pm
by Durango2k
Where inside the bonnet are the two „ashtrays“ to be fitted ?
Blasted and zinced, possibly better then new:
Carsten
#2 Re: Where to fit those 2 guys ?
Posted: Sat Mar 31, 2018 6:51 am
by Mich7920
Hi Carsten,
It's into the 2 air tunnels of the bonnet. There is foam on the 2 small faces of the part fixed with rivets.
Mich
#3 Re: Where to fit those 2 guys ?
Posted: Sat Mar 31, 2018 8:03 am
by Durango2k
I have the felt plus the split-rivets, bit no idea where to fit them. Do you have a picture of their place ?
Carsten
#4 Re: Where to fit those 2 guys ?
Posted: Sat Mar 31, 2018 8:17 am
by Mich7920
Normaly I have but I'm not at home.
If nobody post some photos, I'll do this at nearly 1 PM
Mich
#5 Re: Where to fit those 2 guys ?
Posted: Sat Mar 31, 2018 3:35 pm
by Mich7920
Hi carsen,
This is the photos I took.
Hope it help you
Mich
#6 Re: Where to fit those 2 guys ?
Posted: Sat Mar 31, 2018 5:56 pm
by Durango2k
Hm, that is near the radiator stoneguard frame. I‘ll have a look for holes that would fit nearby.
Thanks !
Carsten
#7 Re: Where to fit those 2 guys ?
Posted: Sun Apr 01, 2018 7:46 pm
by paulsco
Hi Carsten,
I dont know if these will help; they are not mine, I got them off the internet.
You will see that there is a gap between the two brackets that hold the ducts to the bonnet centre section. You should also see a bolt hole in the the duct in this position. the filler panels bolt to this and at the front, to the front of the panel where the headlight bolts.
Take it from me, they are quite difficult to fit :-(
#8 Re: Where to fit those 2 guys ?
Posted: Sun Apr 01, 2018 9:10 pm
by Durango2k
...I‘ll dig in there tomorrow- Plan is to finish the glue works, then let it sit for another 3 days, then take it apart and primer it.
Carsten
#9 Re: Where to fit those 2 guys ?
Posted: Mon Apr 02, 2018 5:30 pm
by Durango2k
Today I had a look and found the spot. Many thanks for helping me, I‘ll re‘ fit them there when time has arrived. Today I started priming another small parts batch, and glued in the remaining flanges.
Next is to re-glue the wing stiffeners / flanges, its all loose, only kept in place because they are welded on their ends.
Its good progress at the moment.
Carsten
