4.2 strange sound coming from engine bay
#1 4.2 strange sound coming from engine bay
Hi all
Had the car out for the first time yesterday and went on a good 30 minute drive. The car is driving really well after a service at XK engineering over the winter, pulling well etc. However the car has developed a strange rattling sound that's quite loud in the engine bay. It almost sounds like something is loose and the engine vibration is causing it to knock. It seems to occur mostly at slow speeds, at idle or when I hit the odd bump but at faster speeds I don't hear it so much. I've no idea if it's the engine itself or another component.
I've done a video here, if anyone can help identify what the sound might be or areas to check that would be really helpful
https://youtu.be/Q15dws5uSus
Trevor
Trevor
- Trev S -
#2 Re: 4.2 strange sound coming from engine bay
Did you check the screw at the bottom of the air filter ?
Michel
#3 Re: 4.2 strange sound coming from engine bay
Under the carbs there are 3 metal overflow pipes these can rattle against each other and on the frame rails.
Bill S1 3.8 OTS.
#4 Re: 4.2 strange sound coming from engine bay
That’s a good call. I had an issue with one of the floats getting stuck and I had fuel leaking out of the overflow pipe before Christmas so XK serviced all the carbs during its winter service so I wonder if that’s where the noise is coming from. Will investigate this weekflatfloor 3.8 wrote: ↑Sun Apr 15, 2018 12:53 pmUnder the carbs there are 3 metal overflow pipes these can rattle against each other and on the frame rails.
Trev
- Trev S -
#5 Re: 4.2 strange sound coming from engine bay
Another rattle could be where the top half of the air filter (the plenum) meets the bottom half (the barrel).
Although they are separated by a rubber ring, I have can them rub against each other at idle of when pulling off from stationary.
With the engine rattling away, try pushing the plenum see if it makes a difference.
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#6 Re: 4.2 strange sound coming from engine bay
That's the air filter, isn't it? You can see it rattling around (unless it's the lack of a steadicam!). Not the filter - the triangular bit on top I mean.TrevS wrote: ↑Sun Apr 15, 2018 9:01 amHi all
Trevor
#7 Re: 4.2 strange sound coming from engine bay
Haven’t had proper chance to have a look but noticed that one of the aluminium floor panels looks like it might be rattling. I got XK to fit a new speed cable so maybe something got moved etc at the time which is causing the rattle. Hoping it’s nothing serious but will report back tomorrow
- Trev S -
#8 Re: 4.2 strange sound coming from engine bay
Well done that man, spot on with where the noise is coming from. Turns out in to the overflow pipe from the centre carb. Not sure how to stop it rattling though and not sure it's completely in the right place so could some please post a picture of their centre carb showing how the overflow pipe is directed down through the engine bay.flatfloor 3.8 wrote: ↑Sun Apr 15, 2018 12:53 pmUnder the carbs there are 3 metal overflow pipes these can rattle against each other and on the frame rails.
- Trev S -
#9 Re: 4.2 strange sound coming from engine bay
There should be a flattened P clip that the pipes pass through. Held on by one of the bolts holding the oil filter base to the block (top RHS I think)
#10 Re: 4.2 strange sound coming from engine bay
Thanks for the help everyone, problem is now sorted. Pipe just needed repositioning and after a bit of adjusting there is no more rattle.
- Trev S -
