Does the paper oil filter actually work?
#1 Does the paper oil filter actually work?
The paper oil filter supplied by the usual's (JLM9544) has an internal diameter of 1 5/16" but the nose in the oil filter head on a Series 2 car is only 1 1/8" in diameter. As a consequence there is a gap for unfiltered oil to escape through. The paper washer on the end of the filter would seal the gap if it had a concentric surface in the oil filter head to seat on but it hasn't so the oil can just pass by.
The question was raised in this thread: viewtopic.php?f=3&t=6122&p=79526&hilit= ... ent#p79526 but never answered.
To make matters worse, the pressure plate fitted at the other end of the filter also has it's raised area with a diameter of 1 1/8" so thanks to gravity the oil filter element sits offset on that plate too.
Originally a felt filter element would have been used. Is this an unintended consequence of changing to a paper element? I've searched but can find no reference to the problem other than the one above but I can't imagine it's gone unnoticed all these years so what have I missed?
1969 Series 2 FHC
1969 Series 2 FHC
#2 Re: Does the paper oil filter actually work?
Are you missing a part? I’m sure there’s a disc mounted to the oil filter housing that’s concentric with the stub the filter passes over. The washer on the end face of the oil filter seals against this. There’s a pic of it on Barratt’s explodes diagram for the S2 filter (up to engine 7r2297)
https://www.sngbarratt.com/uk/#!/Englis ... %207R.2297
Tom
1970 S2 FHC
1970 S2 FHC
#3 Re: Does the paper oil filter actually work?
That's true for engines up to 7R2298 but for engines after 7R2298 that part is no longer fitted and the housing doesn't have the screw in nose to retain it.
1969 Series 2 FHC
1969 Series 2 FHC
#4 Re: Does the paper oil filter actually work?
Hi John....do you have a photo of the head where the filter fits onto..i have found this coolcat filter head identifier but on the one on the right not sure what the beige colour disc is ..Steve
http://www.coolcatcorp.com/FilterHeads/FilterHeads.html
#5 Re: Does the paper oil filter actually work?
Steve, here is a photo of the oil filter head on my engine which I think you'll find is the same as the one in the photo I linked to in my first post.
1969 Series 2 FHC
1969 Series 2 FHC
#6 Re: Does the paper oil filter actually work?
Hi John...although not an E type this is the head iv just taken off a 1971 xj6 (4.2xk engine) the head has the round seating disc although not a loose part...if you zoom in you can see its been peened over in several places ot hold in place....are there any peen marks on your center to show that one might have been on there...for some reason i cant select a photo on my tablet so will pos as soon as.....however have a look for the tiny square shaped peen marks.......Steve
#7 Re: Does the paper oil filter actually work?
Hi John...although not an E type this is the head iv just taken off a 1971 xj6 (4.2xk engine) the head has the round seating disc although not a loose part...if you zoom in you can see its been peened over in several places to hold in place the round disc..are there any peen marks on your center to show that one might have been on there...for some reason i cant select a photo on my tablet so will pos as soon as.....however have a look for the tiny square shaped peen marks.......Steve
#8 Re: Does the paper oil filter actually work?
Steve,
There are certainly some marks, they don't look like peen marks but something's been going on.
Hopefully some more folks with Series 2s will recall what's at the end of their filters. A search of Google images didn't help but did lead to this thread: viewtopic.php?t=476&sid=81e8c2789353106 ... 8bacd144bc
Post no.5 has a similar picture that has no plate but it does look as though the nose has an o ring or packing piece on it.
And this image from Rob Beere's site has a plate on it: http://www.rob-beere-racing.co.uk/pictu ... non003.jpg
1969 Series 2 FHC
1969 Series 2 FHC
#9 Re: Does the paper oil filter actually work?
Hi John...the Rob Beere photo far right is the same as i was trying to post.you can see the peen marks holding the disc on...the photo on post 5 you refer to the disc has been removed to fit the spin on convesion.... Steve
#10 Re: Does the paper oil filter actually work?
Hi John,
I have just refitted mine having changed the pressure relief valve. Wish I had taken a photo!
My engine is 7R53059 and there is a disc that is peaned onto the central sleeve. The seal on the end of the filter seats onto this.
Roger
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
S2 FHC Green
Triumph TR6 Mimosa
#11 Re: Does the paper oil filter actually work?
Mine looks like that, but there’s also a loose disc that can be removed from the filter housing. I don’t know if it was ever peened on, but it’s loose now. The filter/spring assembly keeps it in place when everything’s assembled.
Tom
1970 S2 FHC
1970 S2 FHC
#12 Re: Does the paper oil filter actually work?
Thanks for everyone's comments. So the conclusion is that it's vital to have the circular disc in place over the nose of the oil filter head. The oil filter will fit, but it won't filter effectively without that disc.
Given the number of photos showing that disc missing and like my car, it would be worth all Series 2 owners checking that disc is in place the next time they change their oil filter.
For me, I need to find one of those discs or fit another oil filter head that has the disc in place.
1969 Series 2 FHC
1969 Series 2 FHC
#13 Re: Does the paper oil filter actually work?
Hi John...you could make one....its just a round disc....this is from a 71 XJ6....you just need to confirm dimensions.....0.035 thick.....
#14 Re: Does the paper oil filter actually work?
Hi Steve, yes I had thought of doing that. I know the inside diameter, the thickness isn't critical as the spring at the far ends takes up the slack and the outer diameter just has to be large enough to allow the paper gasket on the end of the oil filter to seat.
1969 Series 2 FHC
1969 Series 2 FHC
