Crunchy reverse gear
Sirjames
#1 Crunchy reverse gear
Post by Sirjames » Sun Jun 10, 2018 12:37 pm
I just completed a lot of work on a 1967 S1
New engine, E type fabs 5 speed box.
The gearbox was already fitted and had done 20000miles, was running well.
With the new clutch, the reverse gear is hard to engage. It can only be engaged if i go through 2nd and 3rd firstly.
I bleed it, the movement of the fork is long, everything seems perfect... but still crunchy when engaging reverse.
Does anyone have any idea?
James
James 67 OTS, 73 OTS 6.0L, and other makes
#2 Re: Crunchy reverse gear
Post by cactusman » Sun Jun 10, 2018 1:34 pm
Crunchy gears are usually a dragging clutch. Reverse has no synchromesh so it will be obvious. Probably just dragging ever so slightly and pulling other gears first uses their synchro to stop motion in the gear box hence no crunch ....maybe a minor adjustment of the actuating rod from the slave is all that is needed...
#3 Re: Crunchy reverse gear
Post by chrisfell » Sun Jun 10, 2018 8:39 pm
Dragging clutch can be an adjustment issue, or it could be the release bearing has worn down to the metal.
zigzagsky
#4 Re: Crunchy reverse gear
Post by zigzagsky » Fri Jun 22, 2018 7:23 am
If it is a dragging clutch, I would advise sorting it asap. My car looks to have suffered in the past and eventually the reverse gear idler was damaged following an eventual clutch slave cylinder failure causing a nasty knock and a gearbox rebuild. The rebuilder said that the fact that the clutch had dragged for some time previous to the failure had been a big contributory factor.
As far as I can see, the problem is often caused by the fact it is very difficult to bleed all the air out of the clutch hydraulic system properly. The pipe enters the slave cylinder at the top and the bleed nipple is at the bottom. Fosseway do a kit to reverse these which means the air can rise above the fluid and be bled off far more easily.
Brian
1969 Primrose yellow Series 2, 2plus2
Boyhood dream fulfilled at last!
mark10337
Switzerland
#5 Re: Crunchy reverse gear
Post by mark10337 » Fri Jun 22, 2018 10:24 am
My mechanic usually bleeds from the clutch system by forcing fluid in at the nipple and pushing it up to the reservoir. Simply uses an "oil can" filled with brake fluid and a home made adaptor on the nozzle to the nipple. Bled in seconds.
-Mark
zigzagsky
#6 Re: Crunchy reverse gear
Post by zigzagsky » Mon Jul 09, 2018 7:43 am
That's a useful tip. Thanks. :smile:
Brian
