Mechanical Oil Pressure Gauge
SimonBrown
#1 Mechanical Oil Pressure Gauge
Post by SimonBrown » Wed May 23, 2018 4:19 pm
I wish to check the Oil Pressure on my Series 2 OTS and already have an old Smiths mechanical gauge. Would anybody know where I could obtain a pipe and fittings to connect the gauge to the car, preferably where the sender screws in?
Thank you
Simon Brown
S2 OTS
#2 Re: Mechanical Oil Pressure Gauge
Post by Heuer » Wed May 23, 2018 5:06 pm
Try M&C Wilkinson as they sell a complete kit so can also supply the fittings without the gauge.
S1 OTS OSB; S1 FHC ODB
cactusman
#3 Re: Mechanical Oil Pressure Gauge
Post by cactusman » Wed May 23, 2018 5:07 pm
Places like Demon Tweeks sell all the fittings and adaptors you will ever need. If you are replacing the unreliable electric one then remove the sender and fit your pipe there. If you are adding it as second gauge then e.g. Demon Tweeks sell T pieces to allow both the electrical sensor and your mechanical one to be plumbed to the same take off at the oil filter housing. Just making clear I have no connection to Demon Tweeks...don't think I have ever ordered from them...
JJC
#4 Re: Mechanical Oil Pressure Gauge
Post by JJC » Thu May 24, 2018 5:23 am
In the US, try Nossinger Instruments, Mamaroneck, NY Smiths dealer. The best !! Just have to add a bit for shipping if you can't find nearby.
SimonBrown
#5 Re: Mechanical Oil Pressure Gauge
Post by SimonBrown » Thu May 24, 2018 8:19 am
Ordered from M and C Wilkinson
Thanks for your help
Simon Brown
S2 OTS
JJC
#6 Re: Mechanical Oil Pressure Gauge
Post by JJC » Fri Jun 15, 2018 7:31 pm
Check my post below......only problem will be shipping cost.
JJC
