Radiator Fan S1
#1 Radiator Fan S1
What is best, in front or back, blower or sucker.
#2 Re: Radiator Fan S1
The original is behind and should suck.
#3 Re: Radiator Fan S1
Only behind the radiator and sucking. Putting one in front disrupts the airflow and reduces cooling.
S1 OTS OSB; S1 FHC ODB
#4 Re: Radiator Fan S1
As David and Julian said, a fan drawing air through the radiator is vastly superior to one mounted in front. For even greater efficiency, find one that integrates with the original radiator shroud.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
#5 Re: Radiator Fan S1
I can recommend the cool cat fan. Fits directly on the mounting bracket for the old Lucas motor and comes with a multi blade fan that sits within the existing shroud to maximise air flow through the radiator. Other than the vast increase in the number of blades it looks original to the untutored eye.
#6 Re: Radiator Fan S1
Especially if you paint two of the opposing blades silver - has got past concours judges in the US!
#7 Re: Radiator Fan S1
That would be cheating
