Jaguar diff additive
adam
#1 Jaguar diff additive
Post by adam » Tue Aug 07, 2018 4:38 pm
I cant seem to find Jaguar diff additive JLM 10814 is it no longer available? what is the best product to use in its place.
Thanks Adam
#2 Re: Jaguar diff additive
Post by Heuer » Tue Aug 07, 2018 4:46 pm
Any diff oil that is marked as compatible with limited slip systems.
S1 OTS OSB; S1 FHC ODB
adam
#3 Re: Jaguar diff additive
Post by adam » Tue Aug 07, 2018 5:09 pm
Thank you David
JerryL770
#4 Re: Jaguar diff additive
Post by JerryL770 » Tue Aug 07, 2018 7:36 pm
How can I tell whether or not I have an LSD in my S2?
Jerome Lunt
Tom W
#5 Re: Jaguar diff additive
Post by Tom W » Tue Aug 07, 2018 8:33 pm
Jack up both rear wheels. With the car in neutral and the handbrake off, turn one rear wheel. If the other turns in the same direction, you have an LSD, if the other turns the opposite way, then you have an open diff. Originally there would have been an additional tag on one of the diff pan fixings, but quite often these are missing now.
Tom
1970 S2 FHC
JerryL770
#6 Re: Jaguar diff additive
Post by JerryL770 » Wed Aug 08, 2018 11:53 am
Thanks for that Tom.
I'll give it a go.
Jerome Lunt
Richardhealey
#7 Re: Jaguar diff additive
Post by Richardhealey » Wed Aug 08, 2018 9:47 pm
Hi Jerome,
I have a LSD and was recommended this:
Lodexol XFS 80W-140 Fully Synthetic Limited Slip Gear Oil
Bought from Morris lubricants online.
Hope this helps.
Cheers,
Rich
