I cant seem to find Jaguar diff additive JLM 10814 is it no longer available? what is the best product to use in its place.
Thanks Adam
#2 Re: Jaguar diff additive
Any diff oil that is marked as compatible with limited slip systems.
S1 OTS OSB; S1 FHC ODB
#4 Re: Jaguar diff additive
How can I tell whether or not I have an LSD in my S2?
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#5 Re: Jaguar diff additive
Jack up both rear wheels. With the car in neutral and the handbrake off, turn one rear wheel. If the other turns in the same direction, you have an LSD, if the other turns the opposite way, then you have an open diff. Originally there would have been an additional tag on one of the diff pan fixings, but quite often these are missing now.
Tom
1970 S2 FHC
1970 S2 FHC
#6 Re: Jaguar diff additive
Thanks for that Tom.
I'll give it a go.
I'll give it a go.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#7 Re: Jaguar diff additive
Hi Jerome,
I have a LSD and was recommended this:
Lodexol XFS 80W-140 Fully Synthetic Limited Slip Gear Oil
Bought from Morris lubricants online.
Hope this helps.
Cheers,
Rich
Hope this helps.
Cheers,
Rich
