Serious brake bleed issues
keithmac
#41 Re: Serious brake bleed issues
Post by keithmac » Fri Sep 07, 2018 1:05 pm
Thanks All,
Lock washer is under the bolt in the photo but are quite flat and should be replaced. I have sourced some quality bolts and will be picking them up today along with a new caliper just in case.
Fingers crossed that this is the fix !
Early 1967 S1 OTS, 1952 MG TD
JerryL770
#42 Re: Serious brake bleed issues
Post by JerryL770 » Fri Sep 07, 2018 4:49 pm
Excellent detective work there Keith :salute:
Well done! I hope that is the real cause and you can now get some miles under your tyres.
Jerome Lunt
keithmac
#43 Re: Serious brake bleed issues
Post by keithmac » Mon Sep 10, 2018 1:11 am
Thanks Jerry,
I hope this is a help to other owners to help in isolating there brake line air traps so they know where to focus their efforts and save time and money.
So
Problem is solved. It appears it was faulty and stretched bolts. In addition a few bolts unthreaded section was too long causing them to feel tight even though they did not fully compress the caliper.
Sadly some of the new "Quality " bolts would not tighten either , replace them with another identical new one , and it would tighten.
This after chasing each hole and spray flushing it out. This is HIGHLY advised as there was considerable crud in each hole
Thanks again to the many members who replied with their helpful advice
Cheers,
Keith
288gto
Russia
#44 Re: Serious brake bleed issues
Post by 288gto » Mon Sep 10, 2018 5:19 am
Glad you finally got to the bottom of it Keith! :swerve:
