Front lamp connectors, white plastic vs. bakelite
Durango2k
#1 Front lamp connectors, white plastic vs. bakelite
Post by Durango2k » Wed Dec 12, 2018 10:00 pm
All,
I received an SNG parcel today, I did order the front bonnet wiring loom.
Sadly, the main headlamp connectors are white plastic - and not bakelite with a centre rivet plus a rear disc.
Would you swap them ? How to clean the old (greenish) contacts inside ? It seems I have to open the rivet, but this can be solved.
Call me an anorak, but...
Carsten
#2 Re: Front lamp connectors, white plastic vs. bakelite
Post by abowie » Thu Dec 13, 2018 2:33 am
You can't see them once assembled.
If you really wanted to clean the old ones I would put them in an ultrasonic cleaner with 25% by volume vinegar and a good squirt of dish washing detergent.
881824, 1E21538. 889457..oops
Durango2k
#3 Re: Front lamp connectors, white plastic vs. bakelite
Post by Durango2k » Thu Dec 13, 2018 3:45 am
If I use acid (of any kind) to clean them, would not some of the acid stay in the edges, and it‘ll deteriorate fast ?
Carsten
JerryL770
#4 Re: Front lamp connectors, white plastic vs. bakelite
Post by JerryL770 » Fri Dec 14, 2018 4:53 pm
Carsten
Not if you neutralise it after. Use ordinary milk which will neutralise both acid and alkali, but then you need to rinse it well, else it may get smelly :roll:
Jerome Lunt
#5 Re: Front lamp connectors, white plastic vs. bakelite
Post by cactusman » Fri Dec 14, 2018 5:02 pm
You can drill out the rivet and dismantle. A M3 bolt and nylock but serve to fix it together afterwards.
