Borescopes & Happy Christmas to you all
#1 Borescopes & Happy Christmas to you all
Post by christopher storey » Mon Dec 17, 2018 11:28 am
I have advocated the use of these many times, but have not had one myself ! Please can anyone recommend what I should get, and from where ? I want one small enough to go in cylinders through spark plug holes
I wish everyone on this forum a very Happy and Peaceful Christmas
#2 Re: Borescopes & Happy Christmas to you all
Post by malcolm » Mon Dec 17, 2018 11:39 am
Happy Christmas to you too!
I haven't bought one of these myself, but was thinking about one for things planned next yearn so looked into it a bit. I quite liked the look of this one because it looks small enough (apparently goes through a 10mm drilled hole) , has HD images and isn't stupidly expensive. Money is saved because rather than an attached screen, or monitor, you wi-fi the images to your smartphone. Gets quite a good write up.
JJC
#3 Re: Borescopes & Happy Christmas to you all
Post by JJC » Mon Dec 17, 2018 12:25 pm
Just google what your looking for...dozens available on line from China. Very cheap, work great. less then $10.00 here in USA. I use as you have suggested, looking into cylinders , etc. You can change intensity of light, focus, etc, and plugs into your cell phone, which takes about 2 minutes to download the app. Great little device.
JJ
#4 Re: Borescopes & Happy Christmas to you all
Post by Series1 Stu » Mon Dec 17, 2018 11:06 pm
I bought one on eBay a few years ago. It plugs into a USB socket, is 7mm diameter and has its own light source, which can be varied to suit. Total length is 2 metres so you can run it up a sill or similar but it can be tricky to control due to its flexibility.
Managed to retrieve a wiper box spacer that fell into the bulkhead thanks to this little toy.
Cost about £7 if I remember correctly.
'94 X300 XJR basket case
JJC
#5 Re: Borescopes & Happy Christmas to you all
Post by JJC » Tue Dec 18, 2018 12:39 am
Hello all ! On EBAY. US 6LED 7MM Endoscope $8.99. Great device.
JJ
JagWaugh
Switzerland
#6 Re: Borescopes & Happy Christmas to you all
Post by JagWaugh » Tue Dec 18, 2018 5:53 am
I have a couple of USB cabled ones (one with a 6m cable, the other 2m).
I recently tried one which comes with a rechargeable WiFi transmitter, and you use an app for the phone to display the image. I like the idea, but the app isn't very good, and I'd rather be able to display it on a (larger) laptop screen. I didn't spend much time messing with it.
I use them fairly often, great to have a look inside a fuel tank to see if a sender is sunk, rubbing etc...
#7 Re: Borescopes & Happy Christmas to you all
Post by christopher storey » Tue Dec 18, 2018 4:04 pm
Thank you all for the advice . Like Andrew, I want to use one with a laptop, so I will need to choose carefully
#8 Re: Borescopes & Happy Christmas to you all
Post by malcolm » Tue Dec 18, 2018 5:15 pm
Hi Christopher - sorry, I didn't post my link! Links to smartphone (IOS or Android) but not sure about laptop
#9 Re: Borescopes & Happy Christmas to you all
Post by christopher storey » Tue Dec 18, 2018 6:43 pm
Malcolm : for some reason, your links are failing to appear
Tony
#10 Re: Borescopes & Happy Christmas to you all
Post by Tony » Wed Dec 19, 2018 12:46 am
Christopher, I have just bought one if you want to try it before purchasing one yourself. Or just borrow mine.
Tony (E typed)
Tony
#11 Re: Borescopes & Happy Christmas to you all
Post by malcolm » Wed Dec 19, 2018 9:38 am
Weird - it appears on my screen when I look at my post!
It comes up as a picture you can click on. Go to Amazon, and put in Depstech borescope, then look at the £29.99 option for Depstech. They do a £39 option that works on tablets, so may connect to a laptop?
#12 Re: Borescopes & Happy Christmas to you all
Post by christopher storey » Wed Dec 19, 2018 10:49 am
Malcolm : thank s for the details, I've looked at it now. Tony, thank you for your very kind offer to try yours out - I shall ring you after Christmas
rfs1957
#13 Re: Borescopes & Happy Christmas to you all
Post by rfs1957 » Sat Dec 22, 2018 2:02 pm
Please let us know what you opt for, Christopher, as there must be many of us tempted by these ...... when one thinks that only 5 years ago I spent upwards of 200 quid, albeit with its own screen, to look for a leak in a model steam locomotive.
I wonder if there's anything available that is also able to look for small items flying over Gatwick ?
1978 Mini Van
Tony
#14 Re: Borescopes & Happy Christmas to you all
Post by Tony » Sun Dec 23, 2018 1:16 am
Mine arrived yesterday and it seems to work fine with good images. Can take pictures ,videos with a few tools for hooking item, magnet end etc. Cannot go to wrong for £29.
Tony (E typed)
Tony
#15 Re: Borescopes & Happy Christmas to you all
Post by malcolm » Sun Dec 23, 2018 10:22 am
Which one did you get Tony? Link?
Richardhealey
#16 Re: Borescopes & Happy Christmas to you all
Post by Richardhealey » Sun Dec 23, 2018 4:54 pm
[/quote]
I’ve just bought this one too, to examine the inside of the cills etc. Testing it looks like it works well and It can take photos etc, so in the New Year I’ll use it and if anyone’s interested I can post some.
Cheers,
Rich
Tony
#17 Re: Borescopes & Happy Christmas to you all
Post by Tony » Sun Dec 23, 2018 11:21 pm
Malcolm, I bought the one you recommended and as posted by Richard Healey above.
Tony (E typed)
Tony
#18 Re: Borescopes & Happy Christmas to you all
Post by malcolm » Mon Dec 24, 2018 9:54 am
I'd be interested to hear feedback! Then I can NOT buy it if it's rubbish!
Seriously, a few pics posted would be good.
