s3 starter motor removal
driver
#1 s3 starter motor removal
Post by driver » Fri Dec 14, 2018 2:22 pm
Hi Rob Gill here,
I am in the process of removing my starter motor, access is very limited ,any one had experience doing this task? :scratchheadyellow:.
Thanks in anticipation.
v12 etype 2+2
#2 Re: s3 starter motor removal
Post by mgcjag » Fri Dec 14, 2018 2:57 pm
Hi Rob....helped a friend on his S3 a long while ago so may be getting confused with my S2....access panel on driver side of tunnel to get to the bolts..and remove clutch slave pipe.....then wiggle it out....if you just look at it you will think there is not enough room...but it will come out.....Steve
42south
New Zealand
#3 Re: s3 starter motor removal
Post by 42south » Sat Dec 22, 2018 4:49 am
I agree on removing the tunnel access panel. I don’t remember the clutch line being an issue.
I also removed the battery and it’s support box.
If you are removing the starter due poor performance, check out the geared starters available.
Half the weight
Faster cranking
Lower current draw
Half the size.
Mark Brown
1971 S3 Etype
Son: when I grow up, I want to be a pilot
Dad: You’ll have to choose.
#4 Re: s3 starter motor removal
Post by Series1 Stu » Sun Dec 23, 2018 1:15 pm
Except that on some the tooth pitch is not an exact match to the flywheel so, while they may initially appear to work, they eventually chew teeth leading to expensive repairs.
'94 X300 XJR basket case
Bob.
#5 Re: s3 starter motor removal
Post by Bob. » Sun Dec 23, 2018 4:05 pm
Hi Rob
You might find this thread of interest http://forum.etypeuk.com/viewtopic.php?p=103478#p103478
Bob
Bob
'71 S3
