Brake slave cylinder
Thim
Norway
#1 Brake slave cylinder
Post by Thim » Thu Dec 20, 2018 4:59 pm
Hey, I'm trying to rebuild my brake slave cylinder / brake vacume cylinder. I'm now very unsure about how the retaining pin is supposed to stress the spring on the slave piston. Anyone who knows?
Jaguar E-type s1, 1967 2+2. Under restoration by myself, slowly seeing the light at the end of the tunnel 👍
Mich7920
#2 Re: Brake slave cylinder
Post by Mich7920 » Fri Dec 21, 2018 9:09 am
Hi Thim,
What I see is that your spring isn't compress and the pin isn't in place.
The pin is inside the piston and dont block it as your's.
The spring comes in support on the pin wich is just alittle bit longer than the axel.
The difficulty is to compress the spring so that the hole's pin is free.
Do that one face after one, the second isn't the more easy...
Mich
Michel
1963 E Type OTS - Angus Restoration
1965 E Type FHC - Front Restoration
Thim
Norway
#3 Re: Brake slave cylinder
Post by Thim » Thu Dec 27, 2018 6:12 pm
Thanks you for the info :)
e-tom
Norway
#4 Re: Brake slave cylinder
Post by e-tom » Mon Jan 07, 2019 8:45 pm
Hallo Thim, If no success with the rebuilding, I have a brand new one in its original SNG box. (jeg bor på Gjøvik)
E-tom
Thim
Norway
#5 Re: Brake slave cylinder
Post by Thim » Tue Jan 08, 2019 9:17 pm
Haha, så bra! Prosjektet går ekstremt sakte da jeg er student i Trondheim og bilen er i Oslo. Men tar kontakt dersom det trengs. Hvor mye skulle du evt hatt for den?
