Series 1 bonnet wiring loom fixation points ?
Durango2k
#1 Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Fri Dec 21, 2018 8:51 pm
Hi there,
How and where is the front bonnet wiring loom bolted to the metal parts ?
Its tricky for me to describe - below the front left lamp there is a short piece of about 15 cm just from the plug to the main „power distribution“, the 10 point plastic carrier.
From that main connector, there‘s a long loom, with eyelets on both ends and the two indicator wires on each end. Obviously, the side „with more wires“ goes to the left, into the main connector. Where do the eyelets go ? There are 2 holes on each side in the main air ducts, I guess into the upper holes ?
Then, the main loong loom is loose. How and where is it fixed onto the underpan ?
Behind the lamps, the wires come out of the black „pots“ on top, and go straight to the hole in the vertical panel. There‘s a rubber bunge in the hole so it‘s water proof. I guess there is a wire clamp on the one unused hole next to the black „pot“ ?
Carsten
Durango2k
#2 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Fri Dec 21, 2018 10:06 pm
I managed to solve one part of the puzzle. Checking through the whole Factory Fit 3.8 thread I found that the upper inner bolt from the sugar scoop was used to put a cable clamp there. I have the clamps, re-zinced, so I‘ll put them there. Easy.
One more point: I only have the stineguard frame, not the mesh. It seems it cannot be bought without the frame ? So- which way around is the frame mounted (I guess it „opens“ to the front ?), and how is the mesh attached ? I can see long strips on the sides of the wire mesh- are these soldered, or just bolted to the frame?
Carsten
paulsco
#3 Re: Series 1 bonnet wiring loom fixation points ?
Post by paulsco » Sat Dec 22, 2018 10:14 pm
Hi Carsten,
This is a picture of the left hand side as I was stripping the bonnet:
The right side:
Stoneguard:
I hope these help,
Durango2k
#4 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sat Dec 22, 2018 10:20 pm
Many thanks ! That is what I needed !
Carsten
Durango2k
#5 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sat Dec 29, 2018 8:36 pm
Hi Paul,
Could you please get me some measures, L1 to L 4 ? I am trying to replicate this bit as good as I can...
Many thanks !
Carsten
Durango2k
#6 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 2:37 pm
...As I had some (unexpected) free time today I fiddled with the stoneguard and this came out:
Now, I found that I do not need the two distance pieces shown at SNG: BD20579
https://www.sngbarratt.com/de/#!/Deutsc ... 0f09d095de
Why is it ? Am I missing something?
And there‘s a second row of three holes for bolts on each side of the inner bonnet, along the air ducts, more evenly spread. Maybe I have the wrong stoneguard frame? Mine is from a 3.8 I think, and it has two near-spaced holes on th bottom and near the top, plus two on the top horizontal bar which just keeps the grid on the frame.
Carsten
Durango2k
#7 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 3:35 pm
... I may have found the explanation for the second row of holes: are they for the S2 fan carrier ? The spacing of the holes looks to be correct for it:
Means that when they built my S1.5 bonnet they knew of the S2 fan carrier already....like the second set of holes in my flywheel.
Carsten
johnetype
#8 Re: Series 1 bonnet wiring loom fixation points ?
Post by johnetype » Sun Dec 30, 2018 4:18 pm
The S2 fan carrier bolts to the radiator frame not to the "inner bonnet".
1969 Series 2 FHC
ysmalkie
Poland
#9 Re: Series 1 bonnet wiring loom fixation points ?
Post by ysmalkie » Sun Dec 30, 2018 4:23 pm
Check out the originality guide, page 1 and photo:
http://i.imgur.com/AaCgZUt.jpg
L1: 19mm
L2: 5.4mm
L3: total length: 52.1mm
L3: distance between the holes: 20.3mm
L3: hole diameter: 7.1mm
L4: 47mm
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Durango2k
#10 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 4:55 pm
Hi Tadek,
Thanks!
I have checked the Imgur picture, but I think something is different. There are no holes „more towards the nose“, and even if I revert the frame so that the long part goes forward I would not gain that depth.
Maybe the design changed with the 2+2 ?
It just looks and feels as if it‘s intended the way I put it in. Only problem would be to get some nuts or bolts into the holes in the underpan / you can reach in through the side holes or from the nose / front now. The later to be blocked by the motif bar later on.
Then, you found L 4 to be 47 mm. In my case, I used a 10 mm spaced grid, so I have around 3x10 plus 3x 1 mm wire thickness, say 33 mm below the frame. Strange...
Carsten
ysmalkie
Poland
#11 Re: Series 1 bonnet wiring loom fixation points ?
Post by ysmalkie » Sun Dec 30, 2018 5:01 pm
NOTE PLEASE: the measurements I have given to you are for the narrower net!
There seem to be 2 types and I just realized this after buying off ebay the wrong one :-(
Anyone knows for which e-type is the narrower net??
Tadek
Tadek
Jaguar XK120 OTS
Durango2k
#12 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 5:17 pm
From what I read the V12 / S3 are different.
Interesting detail is the spacing of the holes on your grey frame: this looks like my „second row“ of holes. The rusty one upfront (wich I would sandblast, zinc and re-use) has a different hole spacing in the side parts. 1 top 2 bottom.
Carsten
paulsco
#13 Re: Series 1 bonnet wiring loom fixation points ?
Post by paulsco » Sun Dec 30, 2018 10:30 pm
Hi Carsten,
I am sorry, I no longer have the original to measure.
The Series Two stone guard is narrower and mounts further forward in the bonnet mouth.
I have converted my Series One to Series Two size as I am fitting AC and needed more room in front of the radiator for the Condenser.
I think that the reason you do not need the distance pieces is that you have mounted your stone guard futher forward in the Series Two position. You have ether made or fitted a Series Two stone guard.
Both sets of mounting holes are available in the bonnet.
Unfortunately I do not have a picture of the stone guard in its new position at the moment, but this is my converted stone guard.
Durango2k
#14 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 10:41 pm
Hi Paul,
Ok thats it then.
The bonnet picture you posted shows three sideway holes mostly even spaced like x..x..x. Thats a Series 1 part. Spacers needed because it is further back / nearer towards the radiator.
The one you adapted is like mine, like x....x.x. Thats an S2 part. No spacers needed because its nearer towards the nose.
I‘ll stay with the S2 one - it will work and it looks nice, „as it should“.
So, we‘re all left with just one question, then (music of X files in the background....):
Why did they include both sets of holes - does it not mean that from a certain point onwards, they knew what would come, and included both sets of holes ? But why ? To ease the spare parts debate - one item fits both models ?
I have puzzled around this since I found the second set of holes on my flywheel...
Thanks for your help!
Carsten
Durango2k
#15 Re: Series 1 bonnet wiring loom fixation points ?
Post by Durango2k » Sun Dec 30, 2018 10:43 pm
...and Tadek has a grey S1 frame plus a complete S2 stone guard setup, then.
Carsten
