Triple SU building tutorial
cooper66
#1 Triple SU building tutorial
Post by cooper66 » Sun Dec 30, 2018 5:43 pm
Hello,
Do you have any tutorial or detailed post for triple HD8 rebuilding please ?
I found some but not really detailed.
Thanks in advance
Pierre
Tom W
#2 Re: Triple SU building tutorial
Post by Tom W » Sun Dec 30, 2018 6:29 pm
They burlen fuel systems website. I found some useful guides on there when I did the HIF6s on my Rover.
https://burlen.co.uk
Tom
1970 S2 FHC
#3 Re: Triple SU building tutorial
Post by mgcjag » Sun Dec 30, 2018 8:06 pm
Hi Pierre ...with the rebuild kit from Burlan you also get a small pamphlet with rebuild info....also look on Youtube some good videos.....and the Jaguar service manual with full details on the carbs and setting them up..I dont know of a How To on this forum.......get yourself 3 cardboard shoe boxes to keep the carb parts in...and make sure you dont mix parts from different carbs......also make use of this forum to ask questions during the rebuild...many have done this to their own carbs already... Steve
#4 Re: Triple SU building tutorial
Post by Series1 Stu » Sun Dec 30, 2018 11:57 pm
Shoe boxes are okay but I find these storage bins much more robust and appropriate for these kinds of job.
https://rover.ebay.com/rover/0/0/0?mpre ... 2250954496
I'm sure they're available from various outlets.
'94 X300 XJR basket case
Geoff Allam
#5 Re: Triple SU building tutorial
Post by Geoff Allam » Mon Dec 31, 2018 5:45 am
They are pretty simple devices to work on. I would suggest that you research exactly how they work first so that you understand the logic in their construction. Only other tip I have is to rebuild them one at a time so that you have a reference for reassembling them. Be very carefull that you do not drop the bells. If you distort them they are done. When polishing mine I CAREFULLY screwed them down onto a sheet of plywood to prevent the buffer from flinging them across the shop. it happens!
Geoff Allam
64 series 1 fhc burning lots of oil
53 xk 120 fhc sitting in garage waiting for attention
#6 Re: Triple SU building tutorial
Post by cactusman » Mon Dec 31, 2018 9:01 am
I'd agree with Geoff....do one at a time. You will probably find that getting them off the engine (especially the one nearest the bulkhead) is much the most annoying part of the job. Each is held on to four studs. The nuts on the top two are a doddle to undo. The two underneath the carbs are not. Most standard spanners are too long. I bought a single spanner and used an angle grinder to chop it in half to make two stubby spanners! Obvious if the engine is out it will not be an issue. They are fairly intuitive to reassemble. When you do, spend plenty of time making sure the three needles are correctly located in their pistons. They have a little mark at the foot of the needle and all three must stick out PRECISELY the same distance from the flat surface of the piston. A PO had messed with mine and one was 2mm further in that it should have been.....caused HUGE tuning and running issues till I finally found the error.
JerryL770
#7 Re: Triple SU building tutorial
Post by JerryL770 » Mon Dec 31, 2018 10:20 am
When I rebuilt my carbs, the most difficult part was drilling the spindles for the levers/stop arms on the ends.
Why these are not drilled for you by Burlen, I cannot understand and the instruction on how to do this was most unsatisfactory.
I'm sure any better advice would be welcome.
Jerome Lunt
#8 Re: Triple SU building tutorial
Post by Heuer » Mon Dec 31, 2018 11:17 am
These are listed in the Forum Knowledge Base:
Balancing SU and Stromberg Carburettors: https://www.dropbox.com/s/6pmcaqykapw7n ... e.pdf?dl=1
SU Carburettor Notes: http://www.jcna.com/library/tech/tech0006.html
SU Tuning Guide: https://www.dropbox.com/s/tc0k3pac07y3m ... 1.pdf?dl=1
SU Carbs.com Tuning guide: http://www.sucarbs.com/tuning2.html
SU Search (SU needle comparison spreadsheet):
https://www.dropbox.com/s/svh1qj4xr1rqw ... s.xls?dl=1
WinSU: SU tuning software: http://www.winsu.co.uk/
S1 OTS OSB; S1 FHC ODB
