Hey, I'm trying to rebuild my brake slave cylinder / brake vacume cylinder. I'm now very unsure about how the retaining pin is supposed to stress the spring on the slave piston. Anyone who knows?
Brake slave cylinder
#1 Brake slave cylinder
Jaguar E-type s1, 1967 2+2. Under restoration by myself, slowly seeing the light at the end of the tunnel
#2 Re: Brake slave cylinder
Hi Thim,
What I see is that your spring isn't compress and the pin isn't in place.
The pin is inside the piston and dont block it as your's.
The spring comes in support on the pin wich is just alittle bit longer than the axel.
The difficulty is to compress the spring so that the hole's pin is free.
Do that one face after one, the second isn't the more easy...
Mich
Mich
Michel
#3 Re: Brake slave cylinder
Thanks you for the info :)
#4 Re: Brake slave cylinder
Hallo Thim, If no success with the rebuilding, I have a brand new one in its original SNG box. (jeg bor på Gjøvik)
E-tom
E-tom
#5 Re: Brake slave cylinder
Haha, så bra! Prosjektet går ekstremt sakte da jeg er student i Trondheim og bilen er i Oslo. Men tar kontakt dersom det trengs. Hvor mye skulle du evt hatt for den?
