Front right indicator dead / help needed
Durango2k
#1 Front right indicator dead / help needed
Post by Durango2k » Sat Jan 05, 2019 10:25 pm
All,
I am now putting the front electrics back together, and I have it all working - except for the front right indicator.
Front left indicator is alive via a green cable with a red stripe, front right should be green with a white stripe (I guess).
Now, where is the indicator relay - I think under the dashboard ? It cannot be fuse 7, because the other side works - there are several pure green wires heading left, I checked them all.
It cannot be the switch - rear both are working.
I also found that the additional hazard flasher does not work - if I flip up the switch, nothing.
Can anyone shine some light on this - where to look next? I think that I should start at the indicator relais, if something‘s coming out there, or not.
Carsten
mark10337
Switzerland
#2 Re: Front right indicator dead / help needed
Post by mark10337 » Sun Jan 06, 2019 5:59 am
Test if you are getting 12v on the signal wire at the light. If you are, it will be the bulb holder or a bad earth.
If not. trace back slowly at each connector along the path. connector block, bonnet connector M, bonnet connector F, etc. etc.
-Mark
Durango2k
#3 Re: Front right indicator dead / help needed
Post by Durango2k » Sun Jan 06, 2019 8:19 am
Hi Mark,
That‘s the point - I am already tracing it back, and current-ly I am at the 8 pin connector. Where is the next connection in the row? Under the dash I suppose ?
Carsten
mark10337
Switzerland
#4 Re: Front right indicator dead / help needed
Post by mark10337 » Sun Jan 06, 2019 10:49 am
next one comes in, up the footwell to the connectors under the dash on the left.
Here it will connect to the rear loom, dash loom and indicator stalk.
There should be a couple of double bullet connectors to allow the branching and the signal to be carried forwards and to the rear.
-Mark
Durango2k
#5 Re: Front right indicator dead / help needed
Post by Durango2k » Sat Jan 12, 2019 7:05 pm
Solved. I found the Y connection on the end of the indicator stalk wires. Problem, no connection from this point into the thick loom. I used a needle to follow the green-white wire up from the indicator just below the Voltage regulator, and then inside the car up to the door opening (close). The 2+2 has a relais and hazard switch there. As the loom vanishes there, and the short wire to the stalk comes out of the thick loom, I decided to bridge the 15 cm.
After doing so, it was all fine again.
Strange, but there it is.
Now, everything in the nose works, both lamps and the sides and so on.
Carsten
mark10337
Switzerland
#6 Re: Front right indicator dead / help needed
Post by mark10337 » Wed Jan 16, 2019 10:28 am
Great news! I'm glad you found it.
-Mark
