I have a 69' Power-locker Salisbury Diff which has a 3.54 ratio.
I would like 3.07 or 2.88.
Anyone know if the crown wheel and pinions from other Salisbury axled cars are interchangeable?
The Jaguar XJ40 and X300 spring to mind.
James
Salisbury Crown + Pinion Wheel Interchangability
Topic author - Posts: 1290
#1 Salisbury Crown + Pinion Wheel Interchangability
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#2 Re: Salisbury Crown + Pinion Wheel Interchangability
The XJ40 and X300 diffs are very different externally so I assume the ring & pinion are too.politeperson wrote: ↑Thu Feb 07, 2019 6:41 pmI would like 3.07 or 2.88
I think you might be OK with the 3.07 in a 3.;4 but not the 2.88 unless you swap the carrier. Spacers enable a bodge but I’m not sure which
ratios.
#3 Re: Salisbury Crown + Pinion Wheel Interchangability
Hi James...not answering your question but plenty of info on this current JL thread..look at about post 70 onwards Dick Maury details using an SNG 3.07 worth you reading....these guys seem to have a lot of experiance swaping crown and pinion...you should get in the discussion.... https://forums.jag-lovers.com/t/307-dif ... ted/371911 .Steve
