Hi all
The Assembly diagrams from SNGB show mudguard brackets (marked as 13 and 18) that are not on my car.
Before I re-fit my mudguards should I be using these on a 1970 FHC? Where do they attach to the frames? Any helpful pictures would be very much appreciated.
thanks
Ash
Inner mudguard brackets
#2 Re: Inner mudguard brackets
These are two L shaped pieces which are riveted onto the splash shields.
They have a 3/8" or so hole in the other end into which is mounted a 5/16" captive nut in a sort of clip arrangement.
The nut sits up under a hole in the triangular gusset at the top of the engine frame and a bolt is passed down from above to secure the splash shield to stop it from vibrating.
#3 Re: Inner mudguard brackets
Thanks Andrew - all understood and very helpful.
Many thanks for the response.
Appreciated as always.
Ash
Ash
Series 2 FHC 1970
1R 20607
1R 20607
#4 Re: Inner mudguard brackets
Ah, there's a captive nut? I wondered why the hole is so big.
New brackets (from SNBG anyway) don't have captive nuts, and the nuts don't seem to be a listed part.
I just used a nut and bolt.
1965 Series 1 4.2 FHC
